Question about Sony Computers & Internet
My Sony soundbar shut off while dusting hts200f. Who do I get it working again
    Master:
  • Sony Master
  • 587 Answers
Sounds like you accidentally pressed the power button while you were dusting and turned it off. You just need to turn the HT-S200F back on.
It's the 1st button on the left of the control panel, which is located on top of the soundbar, in it's center. .
https://www.sony.com/electronics/support/res/manuals/4727/47274141M.pdf
Posted on Aug 19, 2019
6ya staff
SOURCE:
How do I connect my Sony soundbar ht-ct 260h to my blu ray player etc, I have no optical port or arc hdmi port,at the moment connected through the audio lead to soundbar & tv ?
hook your dvd player up to the tv via hdmi, then take the optical audio output from you tv to the soundbar. Make sure to enable to audio output jack in the tv setup menu as some manufacturers disable this jack by default.
Mar 30, 2015 | Sony HT-CT260H Soundbar and Wireless...
Harmon karmon sb15 soundbar sound shuts off
A capacitor on the power board has blown. Take it to a shop or warranty replace if available
Apr 12, 2014 | Harman Kardon SB 16 Main / Stereo Speaker
PhillipssoundBar htl2101A
You have to use the TV remote to set the TV sound option to external. Look on TV setup menu for 'external output' or 'external speakers'.
Dec 15, 2013 | Philips HTL2101/F7 Soundbar Speaker Spkr -...
Model# pcg 71318l
Overheating
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Apr 29, 2013 | Sony VAIO Computers & Internet
Sony vaio pcg-71318L overheating
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
Aug 30, 2012 | Sony Vaio PCG-71318L
My Sony Vaio PCG-61611L won't power on, the battery is fully charged and AC adapter is working (green light goes on). Please help!
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
May 15, 2012 | Sony Computers & Internet
OVER HEATING AN CUTS OUT
try cleaning your computer of dust using a fine air blower from a compressor making sure that there is no?MOISTURE in the air line dust causes static to build up in a computer causing it to overheat any many other problems
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead will cause your computer to shut down or continue in a cycle
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to your hard drive
hope this helps
Dec 15, 2010 | Vizio VSB210WS Soundbar
Game turns on then shuts down
Hello.
You may have a lot of dust in your fan causing the playstation 3 to overheat and emergency shut down before it fries the internals. Try taking some CO2 compressed air spray from your local store and blast the dust out and then try it again. Hope this helps!
Dec 01, 2009 | Sony Video Game Consoles & Games
Sony HT-CT100 soundbar + STR-DG720 = Yes misery, no audio
It's not going to do whayt you want. On the premise that you can't run a dedicated receiver to a dedicated receiver. One processor is not going to override another. The soundbar is a "self contained" closed system. Much like Bose products. I understand what you are looking for, it just can't be done with this product. Options: replace the sony soundbar with a passive polk soundbar or similar and keep the AV receiver or: Return the AV receiver and use the nice, but limited sony amplified soundbar. Hope this helps
Jun 25, 2009 | Sony HT-CT100 Theater System
Computers & Internet Logo
27 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
