Can you tell me if the Convergence IC fix is an expensive one? You say it is detailed: can you tell me approximately how much it will cost.
One of the posts said there is a convergence that you do with a remote. Where would I find that to try that?
Thanks for your help!
PCB's when available,are expensive.Replace convergence IC(s),
re-adjust and you are good to go!
Thank you! I tried to do the convergence and they will not adjust. It seems that it is worse around the bottom and the edges but none the less it is bad. Is this generally an expensive fix? I will call for repair tomorrow is there a good place to look for a technician? THANK YOU VERY MUCH FOR YOUR HELP!
With the original remote go into the customer menu and look for convergence---there is a multi-point adjustment in the customer menu--if some color will not adjust in all directions--one of the two STK-292-040 chips this set uses is bad. if you have questions let me know--Someone called me today here with this same model and problem----???
