So check margin Print Configuration...
You probably have the header in an area that your printer cannot print. On some printers, that area may be as large as the first 1/2" of paper. Try moving the header down to see if that solves the problem. Select File / Setup. Click on the Layout tab. In the From Edge area, make that larger and see if that helps.
What have you tried so far?
