Unpluged and removed the ice maker and humming noise stopped. Just don't know what is causing the noise.
If you had your water cut off to the ice maker and didn't have the ice maker turned off, it was your ice maker. You turn it off by lifting the wire arm and leaving it in the up position.
Please rate solution
I meant to add, if you put your ice maker back in the wire is up in the off position and humming does not start back. You will need to either check a couple pieces inside the ice maker or replace the ice maker. If you would like me to wall you through checking the parts, I'll be glade to help. Just respond back and we will go through them. If you want me to wall you through, you will need a ohm meter handy to check continuity
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
directly.
in refrigerator?
refrigerator?
These will help.
Thanks,.
