Grinders Logo
John Roberts Posted on Jul 25, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need manual. For ctt tools 6 in bench grinder model #ct-6b please
Terry
Level 3:
  • Master 11,377 Answers
  • Posted on Aug 02, 2019
Terry
Master
Level 3:
Answers
11377
Questions
Helped
4625087
Points
152765
I didn't find a manual when I searched.
A similar model for sale shows a vender site, where you might ask the question of whether a manual could be provided to you.
https://www.amazon.com/sp?_encoding=UTF8&asin=B0057PLTL2&isAmazonFulfilled=0&isCBA=&marketplaceID=ATVPDKIKX0DER&orderID=&seller=A1DXFJTFV58TSS&tab=&vasStoreID=
1 Related Answer
Fred Yearian
  • 5603 Answers
  • Posted on Apr 03, 2012
SOURCE: I HAVE A CTT BENCH GRINDER MODEL CT-8B THAT WONTRUN
A lot of the bench grinders have a run capacitor in the base. These occasionally fail and unit will just hum when powered.
Cummins model C-140 Bench Grinder. Can I get an owners manual please?
There is a similar one on eBay, but no free ones. Cummins are known for diesel engines rather than grinders, which means someone else made it and put a Cummins badge on it. Take your pick from any of these.
https://www.google.com/search?q=8%22+Bench+Grinder+manual
They don't need much of a manual anyway, most of the content is on safety. Press switch to turn on and off, one arbor is right hand thread, the other is left hand thread.
https://www.google.com/search?q=Cummins+model+c-140+bench+grinder+manual
Needing left hand thread nut for 50-6 duracraft bench grinder Have not been able to find one.
WEN is a leading power tool manufacturer. They produce many kinds of power tools. This grinder is just another quality product from them. WEN 4276 bench grinder has got 2.1 ampere motors that can run in a 3450 RPM without load.
Mar 18, 2012 • Grinders
2answers
I have a Taiwan made 1/2 hp bench grinder that wont run only hums and now it wont even run if I spin it by hand and no capacitor. Is it junk now.
Hi there, with out seeing it I`d say your brushes are gone and ceasing. I hope this solves your problem.
May 18, 2010 • Grinders
Craftsman manual for Model 21126 6" grinder
What do you need a manual for? It's a grinder, grind something!!
1helpful
Bench Grinders Objects
our bench grinder can be used to keep your chisels, knives, gouges and other similar cutting tools sharp, which every woodworker knows is vitally important. Also, bench grinders are handy for sharpening lawn mower blades, drill bits, gardening shears and more. Additionally, a bench grinder can be used for honing and shaping metal objects when modifications are needed. For instance, perhaps you need to modify a door hinge to make it fit in a certain application. No tool is better for this task than a bench grinder.
Bench Grinders Featues
A bench grinder is a very simple tool. The units are usually listed as 6-inch or 8-inch wheel models, and the 8-inch units are typically a bit more powerful, and subsequently more expensive. A 6-inch model will usually be powered by a 1/2 HP motor, where the 8-inch will be larger, likely 3/4 HP. Two very useful features to look for are a mounted work light, which will directly illuminate your work, and an adjustable rest, which functions much like the tool rest on a lathe. Strongly consider models which have both features. Many also include a clear, see-through spark guard, which will help keep any sparks from flying toward your face. A word of caution, though: such a guard does not replace safety goggles.
Precision work question
Bench grinders aren't designed for precision work. In fact, they're really freehand tools that rely on a good eye and careful touch. And while you can take some tools, like drill bits or turning tools, right from the grinding wheel to the work, it's common for grinding to be a relatively coarse, preliminary shaping procedure, followed by careful honing on a whetstone.
Top Bench Grinders Experts
Oliver Street
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Bench Grinder Expert? Answer questions, earn points and help others
