Big Green Egg Large All-in-One Grill / Smoker Logo
Anonymous Posted on Sep 09, 2009
My BGE(Large) is from 1970s 'Nam and rusting away; need parts
Two questions.
1) My BGE flew over to USA on returning empty C-5 in '70s. It had/has a rusting, flaking, weakening, chrome-plated tubular steel base with rubber wheels. Are replacements available?
2) Clay bbq brick fire holder is broken into 3 pieces. Official BGE site says any good fire resistant epoxy should work to glue it back together but pays NO attention to possible toxic cook-off from solvents in epoxy, although they caution often that one should NOT use any liquid fire starter because clay might absorb solvent affecting taste (and safety??). Why do they NOT seem concerned about solvents in epoxy? Maybe there are no solvents in epoxy???
Wayne Holden
Level 3:
  • Master 512 Answers
  • Posted on Sep 09, 2009
 Wayne Holden
Master
Level 3:
Answers
512
Questions
Helped
221590
Points
1122
Once the epoxy cures completely, the solvents/liquids are gone, otherwise it would never cure. Buy a good quality one for use on cooking containers like the BGE.
I'm in Viet Nam.I need buy cable for pioneer home theater 5.1 dv77.Can you help me.
Hello Nguyen Thai Trong...
Sorry your "dv" MODEL NUMBER does not
resonate with PIONEER 5.1 from the USA...
Please cut & paste the URL and look at the
back of optic, phono (RCA type) and power
connectors on the BACK SIDE of a domestic
USA model...
This might help (I hope)
https://www.ebay.com/itm/PIONEER-DV-C302D-5-1-Audio-Out-3-Disc-DVD-CD-Player-Remote-cables-excellent-NR/323638365164?epid=55042131&hash=item4b5a598bec:g:UUUAAOSwC~9cCZKe:rk:1:pf:0
How to fix a has dryer won't spin
Hello Gloria Starling,
The answer is not going to change much... even without the make & model... but it could be said with more conviction...
You have one & only question ... Sadly no make or model came thru with the question...
While this is LARGELY a USA site... GLOBAL products have been able to get satisfaction here as well...
Dryer spinning is LARGELY the function of the drive motor...
or
The DRIVE BELT.
In the USA you need only go to one of the many Parts houses
and input you make & model...
Issuing forth in great abundance will be PARTS PRICES and procedural videos...
The (opinion) worst prices a pushiest sales folks .... come from one of the BETTER on-line technical DATA... domes from SEARS...
If you take my advice & buy your belts/motors & pulleys...
only after getting MULTIPLE ESTIMATES ... You stand little chance of finding how pricy & pushy SEARS agents can be...
Input your details below:
appliancepartspros.com
repairclinic.com
partsselect.com
Search Over 2 1 Million Appliance Parts
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day
returns
http://repairclinic.comartssellect.com/
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Sep 12, 2016 • Dryers
Big green egg
I converted BGE to gas using parts from popular smoker web site. Please let me know if you are interested in parts list
3answers
Where can i buy a crossmember for a 2002 esteem
The part you are looking for in covered by a Suzuki recall. It was was defective from the start. Take your car to a Suzuki dealership and they should replace the part for you @ no cost to you.
What is the typical element that would break and cause a large leak in the raypak2100 RP system heating system? This is a nice stream of water coming out. When I removed the front cover I notice the pan...
The heat exchanger is almost always the culprit. The rule of thumb for repairs is: replace if the cost of the repair is 1/2 the cost of new or more. If other parts are rusted and will need to be replaced soon, buy a new heater.
Apr 04, 2010 • Pool & Spa
1helpful
2answers
Cannon BGE 3000 petrol generator runs for about 10-20 minutes then cuts out. Just occasionally it doesn't quite cut out, but will get going again without me having to start it.
hi i have a BGE 3000 petrol generator it was working 1 min and stop the next it runs well but there is no power going to the panel on the front any help? thanks
Changes NAM Settings?
Here's some ideas for unlock codes, most phones use the last 4 or possibly 7 digits of the phone number, 4 or 5 - 0's or 12345.
Basically your NAM settings contain the phone number info for a carrier, and you can put two different numbers in the same phone using NAM1 and NAM2, what you have done is switch it to an empty NAM so it is asking for the rest of the programming info to set it up.If you can switch it back to NAM1 it should work again. Most phones have an option in the menu for phone settings that allows NAM switching without needing a code.
Aug 30, 2009 • Cell Phones
2helpful
2answers
I have a sch U740 samsung phone nam 1 code
The lock code should be the last 4 digits of your phone number or 0000.
If that doesn't work, perform an activation by dialing *228 send. Then select option 1. After this is complete your phone's lock code should be reset to the last 4 digits of your phone number.
Top Big Green Egg Grilling Experts
Paul Carew
john h
Are you a Big Green Egg Grilling Expert? Answer questions, earn points and help others
