Watches Logo
Posted on Sep 09, 2009
Timex 1854 chrono,indigo lght not working. 2nd one in 4 mths?
Night light no longer works, could be spring on the push button? had one about 12 mths ago, but after 6mths the same thing happened, Timex replaced the watch, fair play, now the 2nd one has gone the same way?
Anonymous
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Oct 12, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
14
Questions
12
Helped
12338
Points
19
The same problem, after 3 years of use.
Night Indiglo light was very bad.
thought the battery replaced it, the battery was okay.
began to collect but probably need a special tool, the glass cracked)
Hello from Russia, buy them again, excellent watchTimex 1854 chrono,indigo lght not working. 2nd one - 10_12_2012_3_56_11_pm.jpg
  • Anonymous Oct 12, 2012
    model Timex T2M459
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1402
Points
My chrono settings will not reset back to 0.
I have a two year old timex indigo which the green light feature no longer works. The stem no longer presses down. Any suggestions will be appretiated.
Hello Pat Trevino,
My best suggestion is to send (or take) your watch
to your NEAREST TIMEX authorized service center.
(see Returns below: Contacts: address & phones)
The FIRST watch I ever bought for myself is the TIMEX Automatic... Still keeps good time after 51+ years
(certainly better than I do)...
Since then I have gathered a few more watches,
chronometers & chronographs.
Takes a licking & keeps on ticking (John Cameron Swayze)
Timex Group USA
Timex Group USA
Returns
indiglo
Timex Men Easy Reader Date Leather Strap Watch
3answers
Indigo light doesn't work
It is possible that either that the movement of the watch is not aligned properly after a battery replacement.
1helpful
Indigo light is not working properly, battery needed?
Timex suggests that you have a watch repair person change your watch batteries. I think it would be a good idea to try and replace the battery, but if that fails to work, contact Timex for advice. If they suggest that you should replace the entire wath, keep the battery. I have no guarantee that any of that would work, though.
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
2answers
How do you set and deactivate the alarm function.
I did find two authorized dealers:
www.kenmarwatches.com
www.princetownwatches.com
Contact both and request users manual fur your specific model. They must be able to help.
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
4answers
Timex Expedition Indiglo light no longer works?
Replace the back cover with the arrow pointing directly at the stem. Everything should work correctly with the cover in that position.
146helpful
10answers
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
  1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
  2. Press ADJUST to set SECONDS to zero.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.
  5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
  6. Press MODE when done.
  7. To display DATE from Time display , press START/STOP.
  8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
  9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
  1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
  2. With time displayed, press MODE to select Chrono Mode.
  3. Press START/STOP to start.
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
  5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
  6. Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
