Televison & Video Logo
Posted on Sep 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No File and Disc Error message
I was playing a DVD movie and the motion stop and later appears on the screen No File and i try other audio disc still the same message No File/Disc Error,
all other disc put into the device will output disc error or No file the device is samsung HT-TWZ412
Please how can someone resolve this problem
Anonymous
Level 3:
  • Master 822 Answers
  • Posted on Sep 09, 2009
Anonymous
Master
Level 3:
Answers
822
Questions
Helped
240284
Points
2570
Clean dvd first with cd cleaner.. before you change optical lens. lens cannot read data on your disc.
Every disk that I try to watch on movies shows no disc error message it won't play the movies but it does play musical CDs
There are several possible reasons why your DVD player is not playing movies, but is playing CDs. Here are some steps you can take to try to fix the issue:
  1. Clean the disc: Sometimes, a dirty or scratched disc can cause the "no disc" error message. Try cleaning the disc with a soft, lint-free cloth, wiping from the center outwards. Avoid using harsh chemicals or abrasives.
  2. Clean the DVD player: A dirty lens or other components in the DVD player can also cause problems with reading discs. Try using a DVD lens cleaning kit to clean the lens, or open up the DVD player and carefully clean any visible dust or debris.
  3. Check the disc format: Make sure that the movies you are trying to play are in a format that is compatible with your DVD player. Some players may not support certain file types, such as Blu-ray discs or region-specific DVDs.
  4. Check the connections: Make sure that all cables and connections are securely plugged in and functioning properly. Try using a different cable or port if possible.
  5. Reset the DVD player: Some DVD players have a reset button or option in the settings menu. Try resetting the player to its default settings and see if that resolves the issue.
If none of these steps work, it's possible that there may be a hardware issue with your DVD player, such as a malfunctioning laser or drive motor. In that case, it may be necessary to take the player to a repair shop or consider purchasing a new one.
tip
When you try to play a DVD game on Xbox 360 it tries to play as a movie?
c on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
tip
Try this to play DVD movies on your PS2 if it wont play DVD movies.
If your PS2 works fine with Games and just wont play any DVD movies at all.Then you should try this trick to play movies on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:894e4e5.jpg
  3. Press the ps_b_triangle.gif (triangle) Button to enter Version Information Menu that looks like3aef030.jpg
  4. Highlight the Play Station Driver as above and again press ps_b_triangle.gif (triangle).
  6. Highlight the Disc Speed as above and press ps_b_x.gif button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the movie plays itself.If your lens is good then it will play DVD in first go else try again till it PLAY your DVD movie.
Thank you!
When inshirting movies dvd in dvd player showing message on dvd players screen no disc and cant play movies dvd why?
it could be the disc itself dvds really don't age that well a common problem is that one day they just decide to freeze and stop working even though they had only been played a few times the most extreme would be your situation. I would suggest trying newer dvds out if same problem occurs then it is a problem with the dvd player.
2answers
The sound goes on and of when watching a movie
see the cause and fix it: God bless you
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
2helpful
Playstation 2 won't play DVDs
if it's a fat PS2 and
model SCPH 30001, SCPH 35001
(not including the models with an 'R' after the model #.
these models need the following to play DVDs:
- PS2 DVD remote with IR unit
- PS2 DVD disc player (sold with DVD remote w/ IR unit)
- PS2 memory card
you copied the DVD disc to the memory card. you used the memory card to play DVDs.
later models didn't need the memory card to play DVDs.
hope this helps :D
4answers
2answers
Optiarc DVD RW AD-5170A ATA not writing DVDs
sounds like your file is to large by the time it writes in and out or the disks a not to great
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
