2002 Hyundai Accent Logo
Posted on Sep 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My license plate lights are out...what kind of bulbs do i need??
ZJ Limited
Level 3:
  • Hyundai Master 17,989 Answers
  • Posted on Sep 09, 2009
ZJ Limited
Hyundai Master
Level 3:
Answers
17989
Questions
0
Helped
14453267
Points
60858
Check this reference guide...
2002 Hyundai Accent Car Lightbulb Size Guide
Low Beam Headlight Bulb Size: 9003/HB2
High Beam Headlamp Light Bulb Size: 9003/HB2
Parking Light Bulb Size: 2357A
Front Turn Signal Light Bulb Size: 2357A
Rear Turn Signal Light Bulb Size: 1156
Tail Light Bulb Size: 1157
Stop Light Bulb Size: 1157
High Mount Stop Light Bulb Size: 921
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 1156
Front Side Marker Light Bulb Size: 2357A
Rear Sidemarker Light Bulb Size: 168
Map Light Bulb Size: DE3175
Dome Light Bulb Size: DE3175
Step/Courtesy Light Bulb Size: DE3022
Trunk/Cargo Area Light Bulb Size: DE3022
From Sylvania Lamp Replacement Guide
License plate
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp.
I hope help you with this. Good luck (remember rated this help).
5 Related Answers
Anonymous
  • 160 Answers
  • Posted on Dec 10, 2008
SOURCE: Change License Plate Light Bulb
you should be able to get to thru the trunk
Anonymous
  • 98 Answers
  • Posted on Feb 23, 2009
SOURCE: how do you change the license plate light bulb
OK>>> it is very cold here, but nonetheless..I went outside to check on my Oldsmobile for your benefit....On mine (I can't guarantee it is the same for all of the vehicles listed above). If you are looking at the license plate, LOOK UP and you should see the bulb and whatever encasing is there. Mine is in a tube and it is attached with (2) mini bolts that will need to come out first, then it just looks like a simple matter of disconnecting the electrical plug, taking out the old bulb and putting the new one in. I hope this helps someone....
Anonymous
  • 77 Answers
  • Posted on May 21, 2009
SOURCE: '04 honda crv bulb change
Its a 5 Watt light bulb. Just pull it out and take it to the store with you. Just remove the license plate to get to it.
Anonymous
  • 5081 Answers
  • Posted on Oct 08, 2009
SOURCE: 1999 Dodge Neon rear license Plate bulb
LICENSE PLATE LAMP BULB
REMOVAL
  1. Remove screws attaching license plate lamp to rear bumper
  2. Remove lamp from bumper.
  3. Remove bulb socket from lamp.
  4. Pull bulb from socket.
INSTALLATION
  1. Install bulb into socket.
  2. Install bulb socket into lamp.
  3. Place lamp in position.
  4. Install screws attaching license plate lamp to rear bumper.
Anonymous
  • Posted on May 17, 2011
SOURCE: License plate bulb replacement
First off, you have to remove the truck lid liner to a point where you can access the light plug from inside (The light cover will not come out without taking the socket and bulb out first). Twist the light plug and pull out. Then on the exterior of the light, take a small regular screwdriver and slide it in the slots on each side of the light cover assembly and push towards the center of the light. This will release the plastic clips and allow you to pull down on the light cover. Do this to each side, then pull down and out towards you to get the light cover off. Install in reverse.
License plates bulb replacement
The license plate lamps are designed to illuminate the plate and registration tags on your vehicle and make it easily visible to law enforcement. In many states, a burnt out license plate bulb can get you a ticket.
Step 1: Locate the license plate light. The license plate light is located right above the plate.
Step 2: Determine which bulb has failed. Park your vehicle and set the emergency brake. Turn the ignition to the Accessory position and turn on the driving lights. Walk around the vehicle to determine which license plate bulb has failed.
Step 3: Remove the license plate light cover. Remove the license plate light cover retaining screws using a screwdriver.
  • Note: You may need to use a small screwdriver to pry the cover off.
Step 4: Remove the bulb. Remove the bulb from its retainer.
Part 2 of 2: Install the bulb Materials Needed
  • Protective gloves
  • Replacement license plate light bulb
  • Safety glasses
  • Screwdriver
Step 1: Install the new bulb. Install the new bulb in its retainer and ensure it is in place.
  • Tip: Refer to your car's user manual to determine the correct type of light bulb to get for your specific vehicle.
Step 2: Complete the installation. Put back the license plate light cover and hold it in place.
Install the license plate light cover retaining screws and tighten them using a screwdriver.
Step 3: Check the lights. Turn on your car to check if your license plate lights are fully functional.
Plate light does not work, but lights are good and sockets seem good
check bulb the number plate light runs on the same circuit as the side lights so if they are working its got to be a bad earth on the plate light
2answers
2002 crv license plate light replacement
Hi, you need "Sylvania ZEVO 2825 ZEVO LED"
search for it on ebay/Amazon or according to me Aliexpress Homepage
It's the biggest and cheapest worldwide suplier.
Just type the correct name into the searchbox and thats it
wish you luck
2helpful
Need to replace bulbs that lights license plate. License plate and light is part of trunk
raise trunk lid look on the inside behind your license plate light there should be access to the bulb there. You will see the wires going in to the bulb there will either be a flt plate that can be removed to access bulb or where the wires enter there will be a round socket that you can twist counter clockwise and remove the bulb socket for bulb replacement. hope this helps.
16helpful
2000 Buick Lesabre custom liscense plate bulb
kind of tricky, took me an hour to get it figured out, but you got to opend the trunk and take out the 10 or so 10mm nuts sticking out of the backside of the lid, then the whole solid piece where the lights are on the back will slide off, then you can change the bulbs above the license plate and put it all back together
1helpful
2001 LeSabre - replace rear license light. The rear license plate lights do not light up the license at night. How do you get to them? What size bulb do you need?
kind of tricky, took me an hour to get it figured out, but you got to open the trunk and take out the 10 or so 10mm nuts sticking out of the backside of the lid, then the whole solid piece where the lights are on the back will slide off, then you can change the bulbs above the license plate and put it all back together, im cant remember off hand the bulb size, but your local auto parts store will have that info when you go to buy them
1helpful
License plate bulb needs replacing
Remove license plate. Unscrew the screws on the underside of the bumper. Slide the lights back toward the trunk and then down through the opening. Unscrew bulb and replace with a new one.
Reverse steps to reinstall the lights.
2answers
Top Hyundai Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
