SOURCE: Invalid format error with P1600 blu-ray and LG LCD TV 42"
It may be a firmware issue if hdmi works with other items such as playstation.
If no hdmi the main Pcb hdmi ports are bad and the main Pcb would have to be replaced.
Consumers cannot upgrade the firmware so a shop would be the only option.
SOURCE: LG CH08LS10 (Blu-ray Drive)
Hey - sorry to hear you're having problems.
First go here - -please I know it is a pain - but READ a lot - do the test and if you do not glean the fix - keep the results and come back here -
http://www.cyberlink.com/prog/bd-support/diagnosis.do
Thanks
RICESKI
SOURCE: I have an LG 42LC2D TV with INVALID FORMAT ON HDMI2
I have had this same issue.
Problem your tv isnt true 1080p meaning it will not work however when you switch to componet cables goto menu then change the display settings to 720p or 1080i then your HDMI connection should work fine.
SOURCE: A new "Tangled" movie disc not play in Blu-Ray
As newer bluray movies come out they are constantly tweeking the format. More then likely you need to update your bluray players firmware or software. There should be an option under the menu for the bluray player to update the unit of course this will require that you have it hooked into the internet via ethernet cable or wifi network.
Testimonial: "This site was extremely helpful. Received resonse very quickly."
SOURCE: I've bought a Panasonic DMP-BD75
Th following hack should work for your model but you'll need a One For All Universal Remote Control.
This hack is written using a URC 8305 Kameleon 5 and should make the DVD Region Free but you can't change the Blu Ray to Zone Free.
The buttons on the Remote can be very sensitive and it's easy to press the buttons for too long once you have programmed and send the same code twice. For this reason set the 1 to 0 key press sequence up as a Macro on the RED button.
1) select DVD device on remote
2) hold magic button until the DVD button blinks twice
3) enter device code 0490 (DVD button blinks twice)
program buttons with the following codes:
1 - 00191
2 - 00120
3 - 00065
4 - 00180
5 - 00143
6 - 00155
7 - 00122
8 - 00117
9 - 00129
0 - 00123
4) hold magic button until the DVD button blinks twice
5) press 994 (DVD button blinks twice) (KeyMagic on a Kameleon)
6) press magic
7) enter 5 digit code from above
8) press button (1,2,3 etc..) where to program it (DVD button blinks twice)
9) press ESC on the Kameleon
10) repeat steps 1 to 6 for all keys.
Switch on DVD player, make sure theirs no disc in it.
Press the One For all Remote buttons in the following sequence
1, 2, 3, 4, 5, 6, 7, 8, 9, 0
If all works ok the Blu Ray player will reboot and when its finished it will not actually tell you its region free, just simply try it with different region DVDs.
Hi bruce hodsdon, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
I need the Model number so I Can Better assist you
