I have a stanton-vestax cd-11 dual cd player, and was wondering how to get a cd to play on it. I put one in, turned the player on, pushed all the buttons and nothing happened. how does it work?
I have had one of these for many years: Switch it on, you must make sure the two transit screws at the back of each deck are fully unscrewed and loose, let the machine displays settle down, then insert a CD, then press the 'reset' button. There is a built-in delay of about 11 seconds before the deck begins to read. After this the machine should then display the first track number, and pressing the big red button will start play.
Pressing the 'reset' button again stops playback and the CD spins down, but if you leave the CD in there it will eventually re-index and cue up again. This feature is to enable fast, one-button CD changing and it works very well in practice, as the 11 second delay is enough time to take one CD out and get another in there before it tries to read it again.
To stop playback just press the 'reset' button (this is the most used button!) and take out the CD. After the delay, the machine will try to read a CD as normal, but display 'no CD' on the display. There is no stop button, as this unit was designed for continuous use in a club or disco.
Hope this helps. :)
