Brother IntelliFAX 4100 Laser Fax Logo
Posted on Sep 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 71 - Brother IntelliFAX 4100 Laser Fax
kate Winfield
Level 2:
Novelist:
Habit-Forming:
  • Brother Expert 62 Answers
  • Posted on Oct 14, 2019
kate Winfield
Brother Expert
Level 2:
Novelist:
Habit-Forming:
Answers
62
Questions
36
Helped
76841
Points
265
Laser Error showed up with the unit is the piece of machine that composes data onto drum surface and the machine is identifying an issue with it. To Brother Printer Error Code 71which identifies with scanner engine also. The print incapable 71 blunder message needs to manage laser unit polygon engine. The laser unit doesn't fire up on sibling printer till it begins to print. The polygon engine of the Brother Printer more often than not keeps running from 20 to 40,000 RPM's relying upon the model kind.
Methods to fix Brother Printer Error Code 71
-Manual answer for fix Brother Printer Error Code 71
-Switch off the printer and unplug it from the essential power source
-Open the back entryway and expel the polygon engine from the bushing
If facing any problem related to a printer please visit us Brother Printer Error Code 71
Anonymous
Level 3:
President:
  • Master 1,187 Answers
  • Posted on Sep 09, 2009
Anonymous
Master
Level 3:
President:
Answers
1187
Questions
0
Helped
528122
Points
4102
That is a laser alignment issue...
You might get lucky:
1. unplug printer power cord from wall or powerstrip.
2. Turn ON printer (without the powercord plugged in).
3. Plug in powercord and turn ON printer again.
If error code 71 remains .... repeat above steps.... but I would advise replacing ($180 ~ $240) instead of repairing ($150)...
Hope this helps!
3answers
I have a brother mcf-8840d with an error code 71. Any thought on what to do?
Your Error 71 means that the mirror motor can't synchronize with the brains of the printer. The problem is most like the motor bearings, meaning you need an new Laser Scanning Unit (LSU), or it could be the main board acting up
I have a Noritz tankless water heater (model n-132m). I am getting an error code of 71. What does that mean?
The Noritz Manual shows fixed for the following error codes:
11
21
90
99
For all other codes this is the recommendation:
Contact our sales agent if:
• Any other error code appears.
2helpful
1994 4Runner V6 (non-4wd) error code 71
2.4L code 71 - EGR Gas Temp Sensor
3.0L code 71 - EGR Gas Temp Sensor
There is a test procedure to tell if bad sensor or wiring problem, can email diagram to you if like need an email address to send to
Home cinema sony dav f200 error cde c:13:71
ive got a sony dav f200 home cinema system,it lets me play music cds but trying to play dvds(not copied or american) it comes up with and error code c:13:71. what does it mean?
Brother 4100 fax error code # 71
Error 71 is a laser scanner error.
Inkworks
866-381-0541
1helpful
Error 71
fault with the fusing unit
try changing the fuse
see
http://ezinearticles.com/?Xerox,-Okidata-Error-Codes-and-How-to-Fix-Them&id=1053652
Machine error 71
Error code 71 -- ( Polygon motor does not synchronize with the reference clock. ) What ever that means - hope that helps.
Norman Weimar
Norman Weimar
k24674
