Question about Garden
How do I get the side discharge to open when mowing?
I don't have the manual for this older mower and can only open the side discharge to clean it out.
6ya staff
SOURCE:
Anonymous
  • 154 Answers
SOURCE: mowing unlevel mower is brand new
check to see if all the mounts are tight.
Posted on Jun 07, 2009
nova2nv
Bill Linda Rivard
  • 197 Answers
SOURCE: John Deere LX188 lawn tractor battery discharge light remaining o
Check the brown wire feeding your voltage regulator,its between batt and steering wheel behind left side of frame.LX100 series machines had a problem with brown wire not fully contacting terminal in regulator.You will know you had bad contact if plastic is discolored.
Posted on Nov 13, 2009
NNYParts
  • 66 Answers
SOURCE: Older Sears rider mower model 6-25 with Tecumseh stalls.
Sounds like you have a wire grounding to the frame somewhere. Check the wires to see if you see any bare spots or frays. www.nnyparts.com
Posted on May 30, 2010
smith1750
SOURCE: Looking for a parts manual for a Murry Lawn
I have a murrary 22" select and The throttle cable has come loose for the handle. I don't know how to put it back on. Can you help me. It's the type that if you turn loose the handle it cuts off automatically.
Posted on Jun 27, 2010
hkp7
  • 397 Answers
SOURCE: My father in laws mower
Take it to a level spot in the driveway and measure the deck height. On one side then the other. If the mower is a deck on a tractor setup, there should be adjustments to fine tune the height on either side. If it ia a walk behind and measures uneven, the only thing it can be is the wheels aren't raises/lowered evenly or one side has more wear than the other.
Posted on Jun 28, 2011
I need a diagram for toro deck 30753
Hi
I have located both the owners manual and a parts manual with breakdowns of all the components of your Toro 52" Groundsmaster mowing deck.
Both can be downloaded from Toro directly at the following link;
Toro 52" side discharge mower, Groundmaster 120 Toro Direct link.
I hope this helps you and if you have any further needs, please feel free to ask.
Jul 11, 2014 | Toro Garden
Troy Bilt XP self propelled mower
Normally an indication of poor air flow. Replace air filter. Clean outside of carb with carb cleaned to ensure choke is free to operate. Go real slow in tall grass, some mowers don't have the torque to do tall grass, only use 1/2 of the deck width and have side discharge open.
May 10, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Mowing a dry dusty yard- mower running very slowly- some dark smoke also- air filter clogged? thanks
Sounds like you have restricted the air from going into your carburator to the point the mower is just running. Change the filter and if is that dusty you to may want to put on a mask. Be careful. GOOD LUCK.
May 27, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Where is the model number on the frame of a toro recycler lawn mower?
Toro model plates are white stickers with black lettering. On rear bagging models it is usually under the rear bag flap to the left of the discharge area. On side bag and commercial type units it is frequently on the underside of the plate that is just below where you hold the handle while mowing. On older recycler mowers it was on top of the left rear portion of the deck and usually fell off before the mower was very old.
Aug 25, 2010 | Toro Garden
To mulch my grass clippings, do I have to use the side discharge or can I simply remove the bag and insert the rear plug?
Insert the rear plug if mulching is desired. The key to mulching is to mow the lawn frequently.You want to keep the mower deck height high enough to cut the grass and allow the mulching blades to work, but just low enough to actually cut the grass in a smooth uniform height. To low of a cut setting will clog the mower and create a mess. 2 times a week is a good frequency to start with.
Jun 10, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
19.5 Briggs & Stratton dies while mowing
the engine is getting to hot or the oil level is to low check to make sure the engine is getting the air that it needs while running they have air vents in hood as well as on sides of most of those tractors or i would mow for a while & put in a cool place to cool down if i can further help e-mail me wade at wadembly@aol.com
Jun 28, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Saw your post about Black and Decker MM525 Lawn Mower
Most lawn mower mfgs offer a mulching kit which usually consists of a metal plate to block the discharge opening and a mulching blade which just has a longer sharpenned cutting edge.
With a little labor you can make your own.
Johnww1422@aol.com
Apr 19, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
21 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
