Question about LG Microwave Ovens
How I preheat my LG microwave oven modal no MS 2681DS
6ya staff
SOURCE:
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: paint inside microwave oven, Can it be repainted ?
Yes. You need to clean it, sand it shiny, then clean it squeky again.
Then you can get high temperature appliance paint in spray on brush-on form from local appliance part store or places like Wal-Mart and Lowe's.
I would suggest you let it dry overnight with the door open before using the oven.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 17, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: change of lamp in LG microwave oven MS-194A
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 16, 2008
dennis bullard
  • 4090 Answers
SOURCE: Oven not switching on after trying to preheat
If there is not enough airflow around the oven it will turn off for safety. It will reinstate itself once it has cooled.
If this does not recover I suggest you call for a warranty service, but I am hopefiul its just the overheat sensor.
Please rate our help++++Thanks for using fixya
Posted on Oct 06, 2009
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Have a GE Profile Microwave/Convection oven.
It may be a bad convection heating element or just a bad thermal cutout.
If it's less than one year old, it will be fully covered under warranty and you can contract GE here to have an authorized servicer come out and fix it free.
If it's out of warranty and you or someone you know wants to check it out, I'd first suggest you take a look at the "mini-manual" hidden inside the unit (behind the control panel, hidden on the left side behind the grille, or attached to the inside of the outer cover) which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Otherwise, see these files: safety disassembly
Accessing some parts may require you to pull the oven from the wall and remove the cover.
You can download GE owner's manuals and installation instructions here.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Posted on Dec 26, 2009
fieldy14
Adam Jerome_lagudi
  • 456 Answers
SOURCE: LG microwave oven rotating but not heating
I have found that the common cause for this problem is either the 'High Voltage Fuse (HV fuse)' or the 'Magnatron Assembly'. In some instances it can easily be both.
My advice is to read throughly how to discharge a 'High Voltage Capacitor (HV capacitor)' to avoid any injury or worse yet, death.
After doing so you can find the HV fuse runing from the HV capacitor, it will be inside a small plastic casing, you will be able to see with the naked eye if it has blown. If so, replace it.
As for the magnatron Assembly, it looks like a large silver cube with a series of magnets inside it, they are not as easy to test to see if they are faulty or not so if the fuse doesnt repair the issue, replace the magnatron assembly as well. I hope this offers some help. Good luck.
Posted on Mar 21, 2010
Ho to preheat emerson MWG9115SB microwave convection oven for baki g
it is not a convection oven only microwave and there is no preheat. refer to your owners manual.
Jul 22, 2018 | Emerson Microwave Ovens
How to preheat in a magicook 20G microwave
You do not preheat a microwave oven. They are either on or off.
Be sure you never put any type of metal in a microwave oven.
Jan 31, 2015 | In Microwave Ovens
I need a manual book for the LG Wavedome microwave
Hello, ideally we need the exact model number of your Oven however the following is a link to the LG website where you can download a manual for a WAVEDOME
http://www.lg.com/us/support-product/lg-MS-152XC
Jul 30, 2012 | LG MC7849HS Microwave Oven
Microwave Oven LG MS-256EL/MS-257EL The oven does not work in microwave mode however the halogen and the fan assisted plus grill do work.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 16, 2010 | LG Microwave Ovens
Oct 06, 2009 | Microwave Ovens
Pre- heating of Microwave
Place a bowl or mug of water in the oven while preheating.
May 15, 2009 | Microwave Ovens
Microwave Ovens Logo
57 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
