SOURCE: 1994 Ford Thunderbird Wipers Stopped
check the arms there is a cover under cover there is a bolt tighten it back up
SOURCE: Blades slow down when cutting deck is lowered.
the lowerer the deck the more your working the mower. either mow more often or reduce speed
SOURCE: New mower hit small stump, cuts too low now/ can't adjust height
It is a bend blade. I feel your pain...I had a riding lawnmover that took a good two-hours to take apart and chage blades and 3/4 of an acre with old ornamental garden root balls popping up all the time. That was a long summer...
You may want to get the blade ahead of time so whomever can help you look under the mower can change the blade once they confirm it is bent. Even if they can fix the old one it is a blade you will need sooner or later and they are not very expensive.
SOURCE: right side wiper blade operation has failed. Left
Sounds like plastic clip that connects right side wiper transmission to left side & motor broke. You can get the clip at an autoparts store. HELP/Motormite sells them.
SOURCE: John Deere L110 blade brakes wont stop blades from spinning
Are the brake pads on brake levers good? May need replace levers.
