Question about Water Skeeter Boating
I have a water skeeter frame. I'm looking for the pontoons. I heard they went out of business. Where can I find just the pontoons?
    Top Expert:
  • Water Skeeter Master
  • 30,506 Answers
Oh baby pontoons for a canoe type fisher. Check out the link.
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&ei=JTdDXYjAOoyAtQWvgJygAw&q=water+skeeter+replacement+pontoons&oq=water+skeeter+replacement&gs_l=psy-ab.1.0.0l2j0i22i30l3.20554.22900..26317...0.0..0.136.1108.9j3......0....1..gws-wiz.......0i71j0i67j0i20i263.Z6CLZL1_LkM
Posted on Aug 01, 2019
2 Suggested Answers
6ya staff
SOURCE:
Rick Gonzales
SOURCE: 2005 Water Skeeter Pontoon..What kind of pump for the valves
If you look up Halkey-roberts valves you will see the air filler part.
Posted on Jul 14, 2012
How do you know if a fuse is blown in your pontoon tracker boat
On the engine itself is a series of fuses , pull them out one at a time and look. But a fuse shouldn't cause the alarm to go . Blown fuse means no power , no power means no alarm. Never heard of an ignite alarm might that be a gas vapour alarm ... find out where the sensor is
May 26, 2018 | Boating
Opened my sunroof heard a crunch now will not close all the way
You are all incorrect with diagnosis. And there is no button hokd calibration, stop it. Read on. So easy a caveman could do it. 1.5 hr job only removing glass.
(Inside vehicle)Remove the 4 hex screws that attach the glass to the rail guides and remove the glass panel. This will also allow for manual movement of rails. The glass is adjustable(hight only) so mind the position when removing the screws.
. Hold the glass like a pizza pan for it will slide down as u loosen each screw, remove the screws then lift upward and rest glass on roof. Removing the glass will give a good view of both guide rail and concting arms. The crunch you heard was one of the connecting arms plastic rail guide tips breaking. Picture a catamaran for a moment. The pontoons are the plastic pieces that slide fore and aft inside the rail and keep everything aligned. It will be the outside(pontoon) guide piece that failed. When that broke, a lot of play was allowed and began binding. Bless the poor folks who bought a whole new unit for nothing. I fabricated two pieces from the plugs off an older dell power supply. The plugs were the exact same length as the factory guides and even beveled ends. I only had to cut the plugs in half long ways and then install on the slider. Even the holes that are already in the plugs fit the stud (pivot stud that the pontoon slides onto) the guide. Sunroof will not vent if any of the pontoons are damaged. When venting, theses guides(pontoons) pivot upward through a slot on the top side of rail slot and rest on the rail so not to close by wind. Hope this helps. Any questions eamail me at dubyadubyadubya dot maxrevadvisors at g mail.
Mar 29, 2012 | 2003 Chevrolet TrailBlazer
May 24, 2010 | Water Skeeter Guide Lite Pontoon Boat
MOTOR SIT TOO LOW IN THE WATER ON PONTOON BOAT WHEN GOING OVER 3000 RPMS
you need to trim the motor by adjusting it so it is more vertical. It must be angled down into the water too much now and so it is pulling itself deeper in the water,
Oct 07, 2009 | Boating
Wimter storage
Go to website for the vessel and pull up the owners manual. If none, make sure all water is out of the pontoons (assuming aluminum) Remove and store all cushions canvas soft coverings and electronics indoors. Outboard remove and store inside. Syphon bottom of fuel tank for any water if present, Remove fuel lines and fuel water seperators. Plug opening.
Oct 03, 2009 | Creek Company 1018 Outdoor Discovery Craft...
Boating Logo
64 people viewed this question
Top Water Skeeter Boating Experts
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Water Skeeter Boating Expert? Answer questions, earn points and help others
