Bose Cinemate Digital Home Theater System Speaker Logo
Posted on Sep 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bose 123 system and Samsung LED TV problem.....
I have a Bose 123 system and new Samsung LED TV..... I am not sure what I need to get my Bose system working properly. I can get one out of the two Bose speakers to work when hooked up to the TV, but no picture and I am not sure how to go into the TV to fix this. What accesories do I need to get te system to work? Would an optical cable provide picture and sound, or just sound? Would an A/V source explorer do the trick? Please help!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
3397
Points
I need to know how to get video from bose 123 system. hooked up to dishnetwork. i got tv great but no picture on dvd jusr sound.
Daniel Augo
Level 2:
Sergeant:
  • Expert 199 Answers
  • Posted on Sep 08, 2009
Daniel Augo
Expert
Level 2:
Sergeant:
Answers
199
Questions
Helped
52780
Points
593
Yes use the Av cables for this connection . at the back of the TV there should be video in and Audio in connection.
for video its usually the yellow pin so yellow will go with yellow tv & m system
just follow colour code
ansd now u will get visual on the screen .
good luck dude
Trying to hook up Bose AV 321 media system to Samsung LED TV model
You can use a Optical to Analog audio adaptor (found all over the internet for under $30). You'll also need an optical cable that goes between the adaptor and TV. Be sure to set the audio output on the TV settings to PCM audio output, otherwise there will be no output.
Bose 123 playing black & white with samsung 7000
i have the same problem. we need to tell the tv that it is getting a signal from an s video scart. but how?
2answers
The speakers for my Bose 123 suddenly don't work for any source. It had worked well for years. Mute is off. What can I do?
It sounds to me like the Bose 123 is to blame not the speakers. I think you can test the speakers by connecting a 1.5 volt battery for a short while (few seconds) accross any of the speakers terminals. Disconected from the amp. If they are working it will go POP
If it's the Bose itself then the main amp inside has failed.
I am trying to hook by Bose 123 to my Panasonic Vestra 3d tv. I have the cable connected but I am not getting anything
To view a DVD in the Bose system on the TV, connect an HDMI cable (or composite-Yellow, Red, White) to the back of the Bose system (output) and the other end to the input on the back of the TV.
If you have a cable box or satellite and want to get the audio on the Bose system, connect an RCA (white and red) cable to the back of the Bose system (input) and the output on the back of the cable box/TV/satellite.
Switch channels on Bose as needed. Good luck!
How do I setup and new samsung led with a 12 year old bose lifestyle 25 series II?
... According to their manuals. The TV is new so it should cover that end. Bose.com covers the other.
I attached my Bose Cinemate system to my Samsung 6900 LED TV audio output via the mini-phone plug to RCA adapter supplied with the TV. When I do, there is a 60 Hz hum through all 3 speakers. When I...
Hello Mmlaird,
Sadly...
(because Bose is small & easy to carry around)...
((probably new & still under warranty))...
For the reasons stated... I would try the BOSE
first... (however)
"HUM' in an audio circuit (usu. listening to LINE
Current
) is caused by TWO electrical conditions:
- Shabby wire routing
- CHEESY capacitors...
I have written a BOOK-FULL of complaints
about SAMSUNG'S quality ($$) decision to use
inexpensive ... CAPACITORS... (in my opinion).
Over the years... I have recognized that SAMSUNG
has become the poster child for bright pictures,
competitive prices... and high FAILURE RATES for
cheesy capacitors...
Good news...
Because of their competitive prices... They are
quite popular... SPARE PARTS... and REPAIR
kits on AMAZON (and litigation) bearing the
SAMSUNG name have been quite interesting...
Thusly...
SAMSUNG PARTS ABOUND
... (as needed)...
By no means am I saying SAMSUNG is alone in these DECISIONS ... I'll only say BOSE is not a likely
candidate for MARGINAL PERFORMANCE, design
or CONSTRUCTION.
Your choice... (my opinion).
Hope I am helping
Carnac the Magnificent
4helpful
2answers
Trouble locating correct location for tv on/off sensor
i have phoned bose the tv sensor will not work with led tvs becouse they do not transmitt enough power for the sensor to pick it up
2answers
Need the remote code for Samsung 55" led tv 8000 series
You will not have any luck, The Screen only uses RF for control. As far as I know there is no IR receiver on the unit or any RS232!! A nightmare for integrating this product into universal control systems.
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
