Vacuums Logo
N
Noreen Vogel Posted on Jul 22, 2019
The brush will not rotate - Vacuums
Elaine Campbell
Level 1:
New Friend:
  • Contributor 36 Answers
  • Posted on Oct 02, 2019
Elaine Campbell
Contributor
Level 1:
New Friend:
Answers
36
Questions
0
Helped
40633
Points
60
You need to check out the belt make sure its not broken or the roller is in place
Steven E Hall
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 19 Answers
Steven E Hall
Contributor
Level 1:
Welcome Back:
Answers
19
Questions
0
Helped
85149
Points
40
Motor has quit or the belt is broken
Why does the rotating brush not work ?
Check to make sure rotating brush is turned on and check for broken or worn belt
1helpful
My brush is not rotating
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC33's brush bar is not rotating. This is likely to be because the brush control on the cleaner head has accidentally set to 'Hard floors'. In this mode, the brush bar will not rotate. Please recline your machine into the vacuuming position, turn it on, and make sure the brush control is set to 'Carpets'.
I'm confident this will resolve the issue, as using and replacing the wand will not have any effect on the function of the brush bar. It's also important to note that the brush bar will never rotate when the machine is standing upright.
If you would like further assistance after you've checked the brush control is correctly positioned, please get in touch with us directly. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
1helpful
Brush bar doesn't rotate.
Either the bearing in the rotating brush is bad and isn't allowing the brush to turn, or in the majority of cases, the belt is broken.
May 20, 2012 • Vacuums
Carpet brush not rotating
Did you check the drive belt for the roller? If not do so, the smell was the belt drive burning up.
Need to replace belt and cannot figure how to take it apart to get at the belt --- Took Screws off on the bottom but could not get to the belt
You have already removed the screws so lift the brush cover off. Then grasp rotating floor brush at both ends and lift. Clean strings,hair and other debris from rotating brush, paying close attention to the brush ends. Clean the debris from motor pulley and drive belt areas.Grasp old drive belt and remove from motor pulley. Place new drive belt over motor pulley and stretch other end over rotating floor brush in the space between the bristles. Place the ends of the rotating floor brush down into slots on the sides. Turn the rotating floor brush by hand several times in the direction of motor pulley. If installed properly, drive belt will center itself on rotating brush. Reposition brush cover and screw back into place. I hope that this helps you!
Belt not broken.... brushes will not rotate.
most have two belts, brush roll rotates only when head is level with the floor....
Kenmore 116.23513301
If the motor on the power brush is running the belt is bad, if the motor on the power brush only runs when you push the overload, the overload is bad.
1helpful
Brushes wont rotate
the belt has streached go to walmart and get a new one.
Brushes do not rotate
Sounds as though your drive belt has come off. Or you have an object stopping the brushes from rotating.
May 17, 2008 • Vacuums
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
