Used unit, switched it off , 4 hours latter tried to turn it on again but does not switch on. Battery is charged but still not switching on?
Found the reset switch on GO 4V00.710 - look underneath, where the unit docks - small button - need a paper clip to press
Also, reset switch is documented in the Quick Start Guide - see label 'F' in the 'Your TomTom GO' what's in the box.
Hi there have you tried to reset your tomtom the reset switch is on the underside where the sd card goes, you will need a pen to push it
Common problem. Needs a new motherboard, try ebay for the board and remove 10 small torx srews, job is quite easy to do. You will need your product code to reactivate it.
Hi thanks. No help though. I cannot see a reset button under the unit. if I pull the sd card out I still can not see any button. The unit is a (go 4v00.710)Please help
Cant see a reset button under the unit. if I pull out the card I still can not see a button. It's a go(4v00.710)
please help
found the reset button and it did the job
THANKYOU
Hi, it looks like i have the same problem, my TOM TOM GO 4V00.710 will not restart, but i cannot see any re set button, could any one please help
Many Thanks
Steve Radford
my tomtom is pluged in and the green light is on but it will not go on
i have the save problem
wer is the reset boton on tom 710
wont sit on
where is reset button on 710 unit?
i have the go 710 my unit wont read the memory card ?????, how can i reset it ,i dont see any reset boton ,what can i do?
mine will not switch on even after pressing the reset button. my wife plugged my sons portable dvd charger into the tom tom & it hasnt worked since ? any ideas
