SOURCE: emachine failure. no recovery disc.
just go to www.newegg.com and purchase an OEM copy of Windows XP for 99 bucks. thats your best bet. Or you may have a recovery partition on that desktop...if you press f11 when you turn it on it may let you recover from that. good luck
SOURCE: Angel repeatedly asks for discs to do a system recover
Are you the original owner? If you did not make a set of recovery discs, you may have to go to emachines and order them. They are about $20. I recently refurbished an emachine and that is what we had to do.
You will need the model number and serial number. They cannot download it to you either.
http://www.emachines.com/support/product_support.html
Available 5 AM to 12 midnight
PT, seven days a week
866-586-2237*
866-598-2237* United States
Canada
*Long-distance charge may apply, depending on your calling area.
866-586-2237 long distance rates may apply
SOURCE: T6534 RECOVERY DISC
I have this disc, and will make a copy for You if You still need it.
webgal03
SOURCE: My eMachine EL1300G DIDN'T
a clean install of your or a new OS should fix all those problems
Click the "Start" icon on the Windows Vista home screen. Select "eMachines," then click "eMachines Recovery Management." The eMachines Recovery Management program opens.
Click "Create Factory Default Disc." The program will tell you how many discs you will need. Make sure the correct optical drive is selected, then insert a blank disc into that drive. Click "Start" to begin the burning process.
Remove the disc when it is finished burning and label it "Recovery CD 1." Insert the next the next blank disc if one is required. Click "OK" to begin burning the next disc. Repeat this step until all of the discs have been created and labeled. Close the eMachines Recovery Management program, insert the system CD that came with the laptop and restart the laptop.
Press "F12" repeatedly when the eMachines logo is displayed on the screen to be redirected to the Boot menu. Select the optical drive, then press "Enter."
Insert Recovery CD 1 when you are prompted to insert the recovery disc. The eMachines Recovery Management program will open.
Click the "Restore" tab in the list on the left side of the eMachines Recovery Management program window, then select "Completely Restore System to Factory Defaults." The computer automatically restarts and the recovery process begins. Insert any additional recovery discs as requested. The computer will reboot automatically when the laptop has been recovered to its original factory default settings, and you will be taken to the Windows Setup screen.
Set up Windows Vista with your own personal settings.
