The one with the rem tag at the back should possibly be it. Although I still advise you to consult the box or manufacturers wiring guide.
I won't recommend attaching it to the live side of a cigarette lighter because some products might get burned doing so, but some do work with this method...
You can actually try to tap in to the wiring of the cigarette lighter slot, so you don't have to remove it at all. It's easy to get to it from either your fuse box, or at the panel. I advise you to at least put a fuse from the cigarette line connected to you rem port to protect it from over powering. You can even put a jumper from your Head unit's power source to your rem if your up to the task. Just don't forget to add protection fuse to save you a lot of headache in the long run...
theres no tags on any of the wires on the back of the deck except for the antenna, but i have already connected it to the live side of the lighter (since it is 12v) and it works fine (as it turns off and on with the ignition), but for all you people that dont actually know which wire it is i dont recommend that you do that, as you could hook it up to the wrong side of the lighter and it will not work unless the lighter is pushed in.....
