Parental controls
HI,
Do the following for unlock the parental control. For this you should need the remote for the DVD payer.
1. Press the set-up button on the remote (set-up display will come on the TV screen )
2. Using Right arrow button or Left arrow button select DVD Setup menu
3. Using Down arrow select Parental control and press Enter button
4. now you can change the parental rating using up down arrows
If it ask for password the read the following carefully and do the same and enjoy your videos.
PARENTAL CONTROL LEVELS 1-8
The Parental Lock allows you to limit the use of your DVD
Player to only those DVD discs that do not exceed the rating you specify. When
the Parental Control is set, DVD discs that support this feature will play only
after the password has been entered. However, typically only discs produced by
major entertainment companies support Parental Control. Discs not supporting
this feature will be "immune" to Lock-Out.
When you attempt to change the Parental Control setting, you are
prompted for a password. This of course makes sense, as this option would be
useless if your kids could enter the Setup Menu and disable it! If there is no user
password set, you'll be prompted to enter a new password. Choose a 4-Digit
numeric password and write it down in Case
you forget it. Key in the password and press ENTER. After the password is set,
press ENTER on the CHILD option. You can choose from 8 levels of Parental
Control, corresponding to the standard rating system in the USA. The available
levels and their equivalent ratings are listed to the right.
PASSWORD - CHANGE
Here is where you can set an additional password to the
default factory password. The procedures to change an existing password or
enter a new password are the same - you
must enter the OLD PASSWORD, then key
in your new password twice to confirm. If you are entering a new password, or replacing a password you
have forgotten, use the factory default
password of 3351 as the OLD PASSWORD. If you are changing a previously entered
password, you may enter that value as the
old password.
A. Remember to keep
in mind that the key to the the factory default password of 3351
B. Once the factory password has been changed, you should keep the password
written in a safe location as a reminder if needed
Ajin
try 8888 or 7777
thats how mine worked
