WHEN TURNING ON POWER, CANT GET PAST THE WINDOWS SCREEN, TO MY DESKTOP LATITUDE d520
Most likely a Windows software problem. Could be virus caused. Try restarting the laptop and immediately start tapping the f8 key until you see a screen with several boot options.Use the arrow key to select "boot using last known good configuration". If that works, you're done. If not, try restarting the laptop and immediately start tapping the f8 key until you see a screen with several boot options. This time select "boot in safe mode". The laptop screen will look different but will still allow you to run your laptop. Click on the "Start" button, then "Help and Support" and then "Undo changes to your system using system restore". Click on "Restore" and then select a date shown in BOLD when your laptop was running fine. Have the laptop restore to that date. After restarting, you should have full functionality. If this doesn't work, you may have a failing harddrive. Try reinstalling Windows. If it fails during loading, your harddrive is most like failing and should be replaced. If reloading solves the problem, you had corrupt software probably caused by a virus attack.
You can download the drivers from Dell WEB site, the
support download page. Make sure you select your model desktop or laptop,
better still, type in the Service Tag number, it is printed on the label on the
bottom of the laptop and on the back or sides of a desktop. (If the Service Tag
label is missing then go into the BIOS setting and on one of the BIOS pages,
the Service Tag number will be displayed). This will open the page where the
specific drivers for your model computer are located. Also make sure you select
the Windows XP or Vista version of the drivers for your Windows operating
system. Click on this link to download the drivers: -
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
