Hi, download the following
https://www.invacare.ie/sites/ie/files/product_documents/cb0c777f3ae5757757fd8ef0a33840e3ba42daf4_558bb5809301cc5c6a8bc810.pdf
go from page 70 , can you confirm what your error is ?
Regards
SOURCE: Breville spectra kettle, light flashing- cause unknown?
It could mean that the warming element is defective; open.
Simple solution.
Press the C.Lock key on the remote.
This key tunrs on and off the child lock feature.
cheers.
SOURCE: My 99 Toyota Avalon horn does not make any sound.
save yourself the hassle , buy yourself a momentary 12volt switch drill a nice clean hole on your driversside dash and re-wire your horn to it, all the screwing around you'll do to figure out why toyota makes cheesy horn contacts you could have your problem fixed..
on one side of the switch you should run a wire that is a 12volt switched +
on the other side I would run another side run a new power wire to your horn
leave your horns stock ground and just replace the HOTLINE ..
you could even go as far as installing a la cou ca racha horn to bring back that 70's Lowrider feel lol
SOURCE: 2002 Ford Focus Doors lock with key fob, but horn does not honk
there are two seperate horns
SOURCE: phone doesent turn on flashing
Try this , it helped me. 1. plugin the charger (or data cable) for about 15 minutes and keep the red light blinking. 2. while the charger (or cable) is hooked to the phone, remove the battery and memory card for 10 to 12 seconds. 3. keep the memory card out and put the battery back in and whalah, it startes up. (really hope this helps)
