I have a Maytag Neptune MDG6700AWW. The heat comes on intermittenly. Sometimes it will dry the clothes completely other times it won't. Other times it won't dry at all and it does'nt matter what setting in is on.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
