I have a Jenn-Air WW30430W double oven. It was here when I moved in in June. When I turn on the oven (from the switch box), it beeps and flashes F7. What do I need to do to get the oven working?
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition
Check/Repair
F1
Defective touch pad or membrane
Replace touch pad or membrane (this problem is usually the touch pad)
F1
Watchdog on board
Replace touch pad or clock assembly (also called the ERC)
F2
Oven too hot
Replace relay board (if present) or oven temperature sensor
F3 or F4
Open or shorted oven temperature sensor
Replace oven temperature sensor
F5
Hardware and watchdog circuits disagree
Replace clock assembly (also called the ERC)
F6
Missing AC signal
Check for proper voltage
F7
Function key shorted or stuck button
Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button
F8
Analog/Digital supervisory
F9
Door latch supervisory
Check door lock circuit or replace clock assembly (also called the ERC)
F0
Function key stuck
I have a similar problem. The WW30430W's lower oven is showing a "Fr" message. The second character looks like a lower case "r".
Any ideas?
Thanks,
Rome
We have a JennAir Double oven WW30430W. The temperature probe has stopped working. We have ordered a new probe but this did not resolve the problem. What should we do next?
Thanks
CG
Any ideas?
Thanks,
Rome
