Checkyour pressure switch. My guess is the pipe that supplies the pressure is clogged. Remove it - blow it out or replace it. Of course, turn off the power first!!!!
install a pressure control switch in the line from the pump to the cistern of the toilet
that way when the button is pressed , the pump cuts in nd refills the cistern then cuts off when it is full
Glad you got it fixed. Hope you didn't lose all your water in the process, we've been that way at times with our little system (can only afford 450 gal of storage with 650 gal transporter, no well).
Watch those strains on the pipes and make sure any further changes have good one way flow valves for this type system, expense doesn't look so bad when the alternative is being waterless!
If it is starting and stopping, it most likely does have some type of leak. The check vavlve is normally installed on the suction side of the pump, and sometimes instead of a check vavlve or in addition to, there is a foot valve. A foot valve is just a check valve (usually with a screen) at the end of the line in the bottom of the cistern. If you have much suction lift, and the check valve leaks (or any leak in the suction piping) then the water will drop back into the cistern. This will also cause the discharge side of the pump system to drop in pressure, causing the pump to restart. You mentioned removeing the pressure tank, that tank keeps the pump from short cycling when you have low demand on the system. If the pump is higher than the cistern, and you don't see a check valve between cistern and pump then you most likely have a foot vavle in the cistern. Hopefully it's accessable by removing the pipe.
sounds like you either have a leak or the water is returning into the cistern thus filling the lines with air and you getting a blast of air and water. I don't know much about them but logic tells me there should be some type of valve that keeps the water from back flowing into the cistern.
