I have n-70, first it was white display, but phone was working properly without display, when I change the both display ic`s, display is working but light is not working.
I already change he display jack and qual, but same problem. its light ic is sealed.
If anyone have solution give it here.
Thanks
If changing the Display doesn't help and the phone functions without any issue, then the problem could be related to your phone Display IC. When the Display IC is bad, only the light will be displayed instead of the Pictures or graphics. To fix this issue, you'll need a mobile repair technician so that he/she could check the issue. Please understand that this isn't a task for non-technical guy, in case the handset if opened or repaired without proper knowledge or experience, it could bring permanent damage.
But if in case the phone doesn't work when the display is white eg. No calls can be received, or no messages could be received, then it could also be a problem with the phone software. The same problem could only be fixed by flashing or upgrading the phone software.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
My N72 (Nokia) phone’s display shows blank when switched-ON. Blank in the sense means that the display lights are ON, but no images in the display. Sometime the dispay comes and goes. In addition, the phone is not ringing or can’t make calls. Can anybody help me?
My advice : Change the LCD
Take it to your lokal Nokia-Service-Center if you´re not up for the job of changing it yourself.
Its fairly simple to disassemble the phone, and the display can be bought for a reasonable price on the internet.
