My bike is going into gear and revving but not engaging to pull away
IT MAYBE SOMETHING QUITE SIMPLE LIKE, NO FREE PLAY AT CLUCH LEVER, YOU MUST HAVE AT LEAST 5 MM PLAY AT THE LEVER, THAT IS THE AMOUNT OF FREE MOVMENT YOU CAN PUL IN THE CLUTCH BEFORE ANY PRESSURE IS FELT, HAVE YOU BEEN ADDJUSTING THIS, DOES THE LEVER FEELVERY SPRINGY, IF SO BACK OF THE ADDJUSTER AND GIVE YOURSELF SOME FREE PLAY, PORELY ADJUSTED CONTROLS CAN CAUSE THE CLUTCH TO BURN OUT IF THIS OCCURED WHILE RIDEING THE MACHINE IT MAY BE THE CLUTCH PLATES HAVE FAILED, REMOVE OIL FILLER PLUG, A BURNING SMELL WILL BE NOTICED IN SOME CASES, FURTHERMORE, REMOVE THE FRONT SPROCKET COVER AND CHECK THE RETAINING DEVICE HAS NOT COME AWAY ALOWING THE SPROCKET TO COME OF THE SPLINED SHAFT, OR EVEN ROUNDED THE CENTRE OF THE SPROCKET CAUSING DRIVE FAILURE.
