Blenders Logo
Anonymous Posted on Sep 06, 2009
My jugs are leaking too at the bottom. If anybody finds the replacement jugs somewhere please let me know. I have a double smoothie maker model 5787. Thanks! email me at [email protected]
  • Anonymous Sep 20, 2009
    Hi c_e_ball, thanks for your reply to my blender problem. I bought this blender off someone, and didn't know it had a leaking proble. I am wondering if I am missing a piece that goes onto the bottom. What does the gasket look like. I have the blade bottom, then a rubber round peice that sits on that, maybe that's the gasket, then the blender jar. Do I have all the right peices? The person who had it before me tried syliconing it all off, so I have quite a mess to peel off. I am going to try to fit it together and see if I can get it to stop leaking. Thanks again for your reply.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Sep 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
471
Points
My blender would do that if I didn't screw the jar on firmly enough. Sometimes the action of the blades will even loosen the bottom from the jar during blending, so I always hold the jar handle while the blending is going on. That way if it starts to undo, I can twist it back tight. Before I learned that trick I had smoothies leaking out the bottom - what a mess! Also make sure you put the gasket/seal on in the right order. If it's in the wrong place it won't seal correctly.
I need the container which cracked for my Smoothie Elite Model SE2000
The replacement parts for the Back to Basics blenders can only be purchased by Back to Basics. You can call them at 800-668-1989 or go through their website to find replacement parts.
Just go to www.westbend.com, go to the support tab, then replacement parts, and find smoothie makers in their list. Once you have the smoothie maker model list up you just need to find your model.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
1helpful
I have a B to B 'Smoothie Signature' with a leaking and loose fitting shaft bearing. Can I get it apart and replace or tighten something, or do I need the entire container base?
Here is a link to all of the replacement parts available for a smoothie signature: http://westbend.com/support/replacement-parts/smoothie-makers/sa5red-smoothie-maker-signature.html
I am not sure what you mean by shaft bearing, but if it is not on this list, it is not available.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
V5785 mixing part broken (leaking)
I need the villaware smoothie maker top model V5785 as mine broke & can't find anywhere. Please help!
2answers
I have a dual 5787 blender that the jugs are leaking. Can I purchase new ones?
hello
can i buy just the blade kit?
please let me know
Villaware 5787 double smoothee maker
http://www.villaware.com/manuals/VillaWare/V5787_English.pdf
2answers
Double Smoothie Users Manual
i need the book on how to work this item lost mine
1helpful
2helpful
4answers
Need a new plastic pitcher for our villaware 5787 Smoothee
Hello Guest - Would you have the number? I can't find it anywhere...thanks!
2answers
Replacement jar
I have the double one two and need to replace both of the pitchers. Cant find them anywhere
Top Blenders Experts
Mike Cairns
Mike Cairns
john h
ADMIN Andrew
ADMIN Andrew
Are you a Blender Expert? Answer questions, earn points and help others
