I want to know how it works, what the different buttons are for orange button green button. what abc does what 1-15 does etc. I am in Rural ireland and its a hilly area, are walkies only good on flat terraine? ie do you need to be in line sight of each other? Any help would be great regards and thanks in advance -Bob
Bob, Handheld radios will talk line-of-sight up to 2 miles (3.2 km). Any obstacles you put between the radios will shorten the range. Talking from inside to outside you might expect only 1/4 to 1/2 mi. (.8 km to 1.0 km). For best range, hold the radio upright with the antenna perpendicular to the ground.
The buttons can do a variety of functions. It would be subject to how the dealer programmed the radios, so there is no way to tell you what exactly your buttons will do. Some options include Hi/Low Power, Scan, Monitor and Sticky Monitor. The Orange button on top is sometimes programmed as an emergency button when used by public safety (Police/Fire/etc).
The 1-15 would be the channel knob. The radio is capable of several channels. This also would be subject to the dealer who programmed the radio. The ABC switch can also be programmed for various functions. It would be best if you were wanting to know how the radio is programmed to visit your local dealer and have the radio read-out.
This radio when fully charged, should work like any other walkie-talkie, where you press the PTT button when you want to talk, and you release the button when you want to listen.
Best regards.
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
Waste ink full reset
These are the instructions which worked for me on my Canon pixma mp470:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
mp150 and simular printers:
