We have a Zanussi built under oven (ZUF270). Last week we had a new element put in the main oven. The main oven worked once, now it won't come on at all, the light or fan don't come on & the oven doesn't heat up. We've called an engineer who said they will disable the timer. Can we do this ourselves?
SOURCE: fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
SOURCE: zanussi built in oven and grill the element has
If you mean the fan element then take all the racks out of oven and at the back is a panel with 4 screws remove may need a tap with hammer and screwdriver to shock rust etc. then undo screws on element maybe 3 screws pull gently forward(electric off).Try to pull the spade connectors off without losing them into back of oven if you lose them then you will have to take out oven and remove back plate. refit new element.If it was the grill element just follow above and find behind back plate.Hope I helped.
SOURCE: Zanussi ZDQ 595 fan oven not heating
Here is a free video to help you with your cooker fan motor problems
and how to fix them
For all your free videos on appliance repairs remember to
mark us down and leave feedback please
For all your parts visit our site http://www.apart4u.co.uk
