Keyless entry remote
hello Kirk , follow these instructions carefully :
sitting in car with all the remotes you wish to register with the vehicle readily available ,,close all doors ! insert key into ignition and remove 6 times within 10 seconds ,, (hazzard warning lamps will then flash twice) ** note withdraw key completely from the cylinder each time ,, if procedure is done too fast it will not enter registration mode ,, ok ,, insert ignition key into cylinder and turn to the accessory position ,, Push any button on the key fob once ,, (hazzard warning lamps will then flash twice),, at this time the new ID code is entered ,, at this time open drivers door ,, check operation of all remotes ..
enjoy Mate .
