Thank you for visiting Fixya forums.
There are several reasons you may be getting this error code. Each will be suggested below:
FirewallChange your firewall settings in the Security Preference Pane to 'Allow
all incoming connections'. Check to make sure you don't have a firewall
running that has stopped iPhoto from communicating with Facebook.
CookiesThis error code may be an issue with the cookie that Firefox or Safari uses to store the
Exporter's login info. You need to delete the Facebook cookie called
"isfbe". In Firefox you can do this by going to your preferences,
clicking on "Privacy," then find the Show Cookies button. Find the one
whose name contains the term "isfbe". Then click Delete Cookie.
For
Safari you also go to preferences, but first click on "Security," then
click Show Cookies and find the aforementioned cookie and delete it.
After this, just go back to the Facebook Exporter in iPhoto and login again, this time you will have no connection problem.
iPhotoiPhoto, a problem lies in a conflict with the
latest point update for iPhoto '08, version 7.1.3. Maybe it will work
if you reinstall iPhoto, update to 7.1.2, copy the iPhoto application
and rename it "iPhoto old," and then run Software Update and bring it
up to date to get the bug fixes in the latest update for your main copy
of iPhoto.
Note: I don't know if it will change the library format at all with
7.1.3.
The FAQ/support page for the Facebook Exporter for iPhoto is here: <
http://www.facebook.com/help.php?page=718>
Login1. Log out of Facebook through your web browser.
2. Go to Facebook Exporter for iPhoto, click Login.
3. This will open a Facebook login page in your web browser.
4. Log in but do not check "Save my login info..."
5. Go back to iPhoto, hit continue, and export your photos.
Sometimes an error message may still occur while uploading the photos, but retry and eventually it should work.
LittleSnitchIf you have Little Snatch running on your computer it may be blocking iPhoto from access port 80.
For
some reason with the Facebook export it doesn't pop up and prompt you
to allow access. Allow access in LittleSnitch my
Facebook plugin for iPhoto may allow you to start connecting properly.
FULL Reset of Safari You can remove all history, cache, cookies, etc.
Firefox HistoryIf your browser is Firefox, clear history.
Hi sasha goodman, I want to help you with your question, but I need more information from you.
Call FACEBOOK HELPLINE Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7///
