According to the operation manual for this model, DL (dual-layer) discs are not mentioned, so your unit may not be able to record or play that type of disc.
Of course, if you are using BLANK dual layer discs which have not been recorded or formatted on any other device, and the LG isn't recognizing them, then the disc type is probably not compatible with your model. It's likely to be a design limitation specific to this model; not necessarily a fault.
SOURCE: How do i hack into the LG DR275 Recorder to make it region free?
this one worked 4 me thks murderface
SOURCE: unlocking LG DR787T
It might be that you burned it to a cd-r. Is it possible it won't read cd-r but should be burned to a DVD. I might be wrong on this but with my (other brand) burner I kept getting a error and thought my 'corder was broken but it was that I was trying to get it to read a cd-r.
SOURCE: LG super blu player won't play blu ray disc
Have you updated the firmware on it? I had a similar problem with a Sony blu-ray player and I had to download an update and burn it on to a CD then allow the CD to update the blu-ray player. What's the model number of your player, I may be able to get a link to the update for you.
SOURCE: My LG BD370 plays all my dvds except two despite
This is probaly a firmware issue you coulkd try downloading the latest update from this link.
http://www.lge.com/uk/support/product/support-product-profile.jsp?customerModelCode=BD370&initialTab=drivers
you will see upgrade instructions for bd300 further down the page, follow this procedure as all models should work in the same way.
please make sure you do not disconnect the power while doing the upgrade as this may render the machine useless.
SOURCE: LG RH278 HDD/DVD Recorder
I have an LG RH278 HDD/DVD Recorder, which was suffering from the problem that it could not play any bought DVD movies, which were previously working fine in that same player. It would however play svcd and DVD+R/-R movie discs.
The solution was to replace the laser tray. I found a new LG DVD BD lens LPC-815 laser tray here: http://www.laser-xh.com/en/?act=showproduct&proid=1147
I bought two for $5.50 each. Shipping was $32 (DHL), all together $45.10 (PayPal fees included). Delivery was fast and accurate within 3 working days (China - Sweden).
