Hotpoint electric stove (older model push button) quit working
I have an older model hotpoint electric stove, with push button controls for the burners. My oven element burnt out, so I replaced it, then suddenly nothing works. I have a small light that tells me when the oven is on, it will light, but I have no oven, no broiler, no burners. So, yesterday I took the new oven element back out, seperated the wires, turned my breaker back on, tested a top burner, and it came on for about 10 minutes and then it went off by itself. Now, I have nothing at all working on this stove except for the little oven light still will light up. Please help, this was a great stove.
Thanks,
Judy
I can suggest some general steps you can take to troubleshoot the issue with the 115V outlet on your Hotpoint built-in electric stove:
Check the power source: Make sure the stove is properly plugged in and that the circuit breaker is on. If there's still no power, try resetting the breaker.
Inspect the wiring: Look for any loose or damaged wires around the outlet or control panel. If you're not comfortable working with electrical wiring, it's best to call a professional.
Check the outlet: Use a multimeter to check if the outlet is providing power. If it's not, it may need to be replaced.
Contact the manufacturer: If none of the above steps solve the problem, you can contact Hotpoint for assistance or to request a wiring diagram.
Remember, working with electricity can be dangerous, so it's important to take appropriate safety precautions and seek professional help if needed.
You are having connection issues, or a failing keypad. Disconnect the power. Pull down the control panel and disconnect the thin, flat ribbon connector that goes from the keypad to the control board, then re-connect the power and see if the F1 returns without the keypad attached. If it returns, get the computer board rebuilt at Corecentric Solutions. If the F1 doesn't return, buy a new keypad... Help Me Find My Model Number RepairClinic com
The beeping indicates to me that the clock has power to it and it's the problem and needs to be replaced. ya need model number to order part it usually can be found on rim around door or inside of the bottom storage drawer, when ordering parts its call by 4 names, all are the same part its either clock, eoc,oven control,or relay board
Here is a link for you to download a PDF instructional manual for your Hotpoint cooker or Hotpoint oven. how to use this service 1 click on Link, 2 click manufacturer (Hotpoint) 3 enter your model number and download the PDF file . http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do
