Garden Logo
Gary Hull Posted on Jul 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cub cadet 1000 serie -the pto will engage - Cub Cadet Garden
Ron Stone
Level 2:
Sergeant:
  • Expert 408 Answers
  • Posted on Oct 10, 2019
Ron Stone
Expert
Level 2:
Sergeant:
Answers
408
Questions
0
Helped
112365
Points
562
Isn't that what you want?
5 Related Answers
Anonymous
  • 15935 Answers
  • Posted on Feb 20, 2009
SOURCE: A short in the pto wiring perhaps?
Form what you are desribing you have a direct short, probaly in the wiring going to pto. I t has rubbed somewhere and is causing your short. Unplug the wires at connector close to your pto clutch and try it again and see if fuse stuill blows after you unhook it.
If the fuse still blows it is in the wiring going back up to thje switch. If the fuse does not blow after unhooking wiring connector the problem is in the clutch.
Thanks for using FixYa - a FixYa rating is appreciated!!
panilling9
panilling9
  • 284 Answers
  • Posted on May 26, 2009
SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Anonymous
  • 109 Answers
  • Posted on Jun 29, 2009
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Anonymous
  • 130 Answers
  • Posted on Jul 18, 2009
SOURCE: electric pto won't stay engaged on LT 1045
you have a shortage or your clutch is going bad
Anonymous
  • 146 Answers
  • Posted on Jul 07, 2010
SOURCE: cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
I have cub cadet series 1000 42 cut. the wire that hooks to pto has been cut underneath. I need to know where black wire goes, I can see where to hook red wire to
I'm not able to reconcile pto wires and a 1000 42.
What is the model number on the label underneath the seat of this unit?
Cub cadet series 1000 rpm goes up then mower dies. Is this the PTO switch?
Sounds like the symptoms of a lean fuel mixture, possible a plugged carb jet.
Looking for the sensor schematics for a cub cadet series 1000, LT1050 hydrostatic lawn tractor. anyone help me?
Try looking at the directional lever at the Transmission. The PTO for the deck will shut off when shifting into reverse. You may have to simply disconnect or jumper the reverse switch depending on if it is normally closed or normally open. Try it both ways to see what works. Also check the engine oil level, The low oil level switch will shut the engine down if more than a quart low.
1806 cub cadet PTO blows fuse when engaged
check the pto switch..un hook it if thats it then replace
I have a cub cadet series 1000 LT 1024 need to replace drive belt, how do i get the pto clutch off?
You donot get PTO of to change the belt. if you want to take the pto
clutch Need to turn the opesit way left
2helpful
3answers
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
2answers
Electric PTO on 1500 series Cub Cadet won't engagewithengine hot
its the electric clutch on the engine that engages the belt to run blades check the centrifical clutch or electric clutch
Jun 21, 2009 • Garden
Top Cub Cadet Garden Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
