Air Conditioner not turning on. Thermostat clicks on but nothing else. I opened up the air conditioner and there was nothing was clogged and there was only a drop of water in the water pan.. What else can I check??
Need to check the breaker to the unit at the electrical breaker box. You should have a dual 60 amp breaker that runs the unit. Also if you removed the front of the furnance on the inside the system will not work unless the front of the furnance is on. There is a safety switch that will not allow the system to run with the door off. There could be the problem if the breaker is on and electricity is supplied to the unit that switch may be out and need replacing. The furnance is operated on 110 volts the condensor (outside section) operates on 240v you need to insure that the proper voltage is supplied to both.
Since both units work together yet operate seperately if the furnance comes on and the condensor doesn't then there is an electrical problem at the condensor (more than likely the contactor switch) if the condensor comes on and not the furnance then there to is an electrical problem (either 110 volts not supplied) or the switch to the safety cut off is bad. Now if neither furnance nor condensor comes on there could be improper power to both or a bad thermostat since the thermostat activates both furnance and condensor. Good Luck on repairs
Dave
Testimonial: "Very helpful. Thanks so much!!!!"
Turns out to be the breaker.. The breaker in the circuit board was bad and so was the breaker for the emergency shut off.. its all fixed! Thanks!
