That depends on how your TV is set up for radio reception.
Some TVs have a dedicated FM/AM radio tuner. This requires signals from both forms of radio antenna.
More commonly now though, digital TV includes a wide range of radio stations broadcast as part of the TV range. In the UK, the radio stations are grouped in the 700+ channel range. e.g. 701 is BBC Radio 1.
Not the tv problems,this problems are the tv stations channels broadcasting tv stations,it is the problems of the tv stations.Some tv broadcasting stations channels are roaring sound some are normal or smaller.Just use the tv volume control + - adjust the tv suomd that all.
The Archos 404 attaches to the TV using either a DVR Station or a special AV cable. The AV cable uses a special small audio-style mini plug on one end to the standard red, white and yellow composite video connectors on the other.The docking station can record from and playback to the TV. The DVR Station 5 uses S-Video and red/white RCA plugs for connection to the TV. Optionally you can use the yellow/red/white composite connections instead. Hook it up similarly to a VCR, input from the cable box to the input of the DVR Station and output of the DVR Station to the input of the TV.
Yes,it not the tv.The tv stations broadcasting signals,u having problems with it.Ask ur cable compannies or satalites dishes about it.They having more contract disagreement more lately with the tv stations and broadcasting tv signals wright lately.
Get into the menu and find the type of signal you want...cable or over the air. Set for cable and hit auto program! Be sure have a connection to the RF connector.
Toshiba TV 2151TB Tuning Press remote button adjacent to the picture brightness button. The symbol of a clock appears. Press the button again and the >>> symbol appears, this is for course tuning. Touch the Increase Volume button and auto tuning starts. When a station is found two green underlines appear. Type the station number i.e.for 2 type 02, this stores the station. Touch the Increase volume button again to find the nexr station. Upto 39 stations can be stored. Fine tuning of any station is achieved by pressing the tuning button until three blocks sysbol is displayed. Use the Increase/Decrease Volume buttos to fine tune the station.
The term digital in this case is the mechanism used to tune in stations. Rather than making adjustments using a front dial to fine tune the stations, there are digital circuits that will lock in the station. The "digital" stations you are referring to now are the over-air digital broadcasts what use a different method for transfering the signals over the air. These stations now broadcast a digital stream of information rather than an analogue TV signal. If you are using an antenna for receiving these over-air broadcasts, you will require a converter.
Set your TV to channel 3 or 4. Then press TV/VCR which is above the button on the bottom right of the remote. Then you can tune in TV stations from the unit.
