1.I HAVE ON THE BUTTOM OF THE SCREEN A REINBOW OF RED KIND OF COLOR AND THE LEFT UPPER CORNER
2. SCREEN SOOMS IN AND EVEERY TIME A CHANGE CHANNELS GOES BACK TO NORMAL AND AFTER A SECOND SOOMS IN AGAIN.
Check the other posts for convergence problems. This may be what you're experiencing. Have you tried bringing it in with multipoint convergence? It's under Menu -> Picture -> Manual Converge -> Multipoint Red and Multipoint Blue.
There should be a reset button on the back or under the battery cover. if that doesn't work, then you can try to connect to the computer and reload your program. If you don't have the software you can find it at the phillips website. If you can't find the website email me the model and I'll try to find for you.
Most likely you can adjust it in the Service Alignment Mode (SAM).
Press 062596 followed by the STATUS button (upper left). Navigate to "White Tone", press the right key to enter and select "Normal" mode. Set the colors:
Red = 135, Green = 128, Blue = 133.
The "Cool" and "Warm" menus are deltas from the "Normal" settings:
COOL: R -3, G -1, B 5 WARM: R 2, G -3, B -13
Press the "MENU" button to return to the main menu, then the "Power" button to turn the TV off.
Move any speakers or electrical devices away from the set. It could also be anything electronic or magnetic. Anything near the set that generates a magnetic or electromagnetic field could be causing the distortion.
KIT10 $29.50 Repair Kit for Hitachi convergence Chassis DP-14G KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
