Computers & Internet Logo
Posted on Sep 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a M2A74-AM Motherboard by Gigabyre. I have no place to install the small floopy drive cacle or power supply. Do you have adaptors?
Lee Hodgson
Level 3:
  • Gigabyte Master 4,810 Answers
  • Posted on Sep 03, 2009
Lee Hodgson
Gigabyte Master
Level 3:
Answers
4810
Questions
Helped
1782920
Points
15941
That motherboard does not support floppy drives as the manufacturers have dropped floppy drives from all new computers, motherboards etc.
You won't even get an adapter for the board either.
My advice to you is to purchase a USB floppy drive and use that for your computer.
If you want to boot from the floppy then the BIOS will allow for the USB floppy drive to be the first boot device.
Regards.
How can I use a SATA HDD in a 7NF-RZ motherboard? What cables/adapters are required?
Hey there. To install SATA devices on any motherboard follow these steps:
1- Make sure your Motherboard supports SATA, a 7NF-RZ works fine.
2- Install the HDD on your case, usually you have to screw it in or if you have a newer case you can lock it in place with a latch.(The SATA slots on a case are usually above the optical drive slots).
3-If you have another HDD already installed, and you don't want the new HDD to have system files, make sure it's designation is set to Slave. To do this, remove the jumper on the HDD pins(a white plastic connector) with tweezers, and, according to your HDD specifications, move it up or down to Slave designation.
4-Use a SATA cable from your Power Supply and connect it to the HDD, then, use a SATA adaptor cable which should have come with your HDD and connect it to the HDD, then to your Motherboard SATA adaptor(these vary from motherboard to another, so use your Manual to specify where it is).
5-Boot up your computer, and enter BIOS. Usually press either F2,F5,F12 or Esc. After that go to Auto-Detect drivers. When you're done, Save & Exit.
You should have successfully installed your new HDD!
Hi i buy all pc parts but i can't fit it how can i fit it?
Step 1: Installing the motherboardp1010185.jpgMake sure you have all the components in place and a nice, clean and big enough place to work with.
Put your antic-static wrist ******** to prevent your components from getting affected. Make sure your hands are clean before starting. First we will be installing the motherboard which is a piece of cake to install.
  • Open the side doors of the cabinet
  • Lay the cabinet on its side
  • Put the motherboard in place
  • Drive in all the required screws
Tip: Most motherboards come with an antistatic bag. It is advisable to put the motherboard on it for some time and then remove it from the antistatic bag before placing it in the cabinet.
Step 2: Installing the CPUCPU is the heart of a computer so make sure you handle it properly and do not drop it or mishandle it. Also try not to touch the pins frequently so that they do not get dirty. Get hold of your motherboard and CPU manual. You need to place the CPU on the dotted white patch of the motherboard in a particular fashion for it to fit properly. There is a golden mark on the CPU to help you assist. Consult both your motherboard and CPU manual to see which position it fits exactly or you could also use try all the 4 positions.
  • Lift the CPU lever on the motherboard
  • Place the CPU properly on the motherboard
  • Pull down the lever to secure the CPU in place
Warning: Do not try to push the CPU into the motherboard!
Got the thermal compound? Now is the time to use it. Take small amount of it and carefully apply it on the top surface of the processor. Be careful not to put it on the neighboring parts of the motherboard. If you do so clean it immediately using the cloth.
Tip: Thermal compounds should be changed once every six months for optimal performance.
Step 3: Installing the heat sink0181.jpgAfter installing the processor we proceed to installing the heat sink. There are different kinds of heat sinks that are bundled with the processor and each has a different way of installation. Look into your CPU manual for instructions on how to install it properly.
  • Place the heat sink on the processor
  • Put the jacks in place
  • Secure the heat sink with the lever
After this you will need to connect the cable of the heat sink on the motherboard. Again look into the motherboard manual on where to connect it and then connect it to the right port to get your heat sink in operational mode.
Step 4: Installing the RAMinstallingram.gifInstalling the RAM is also an easy job. The newer RAMs ie. DDR RAMs are easy to install as you don't have to worry about placing which side where into the slot. The older ones, SDRAMs are plagued by this problem.
If you want to use dual channel configuration then consult your manual on which slots to use to achieve that result.
  • Push down the RAM into the slot
  • Make sure the both the clips hold the RAM properly
Step 5: Installing the power supplypsu1.jpgWe will now install the power supply as the components we install after this will require power cables to be connected to them. There is not much to be done to install a PSU.
  • Place the PSU into the cabinet
  • Put the screws in place tightly
Tip: Some PSU have extra accessories that come bundled with it. Consult your PSU manual to see how to install them.
Step 6: Installing the video card 110665-2107p146-5b.jpgFirst you will need to find out whether your video card is AGP or PCI-E. AGP graphics cards have become redundant and are being phased out of the market quickly. So if you bought a spanking new card it will certainly be a PCI-E.
  • Remove the back plate on the cabinet corresponding to the graphics card
  • Push the card into the slot
  • Secure the card with a screw
  • Plug in the power connection from PSU (if required)
High-end graphics cards need dedicated power supply and if your graphics card needs one then connect the appropriate wire from PSU into the graphics card.
Step 7: Installing the hard disk042b.jpgHard disk is another fragile component of the computer and needs to handled carefully.
  • Place the hard drive into the bay
  • Secure the drive with screws
  • Connect the power cable from PSU
  • Connect the data cable from motherboard into the drive
If your hard drive is a SATA one then connect one end of SATA cable into the motherboard and other into the SATA port on the hard disk. If your hard disk is PATA type then use the IDE cable instead of the SATA cable.ide-sata.jpgTip: If your PSU does not support SATA power supply then you will need to get an converter which will convert your standard IDE power connector to a SATA power connector.
Step 8: Installing optical driveThe installation an optical drive is exactly similar to an hard drive.027.jpg
  • Place the optical drive into the bay
  • Drive in the screws
  • Connect the power cable and data cable
Tip: When installing multiple optical drives take care of jumper settings. Make sure you make one as primary and other slave by using the jumper. This is not applicable if the drives are SATA drives.
Step 9: Connecting various cablesFirst we will finish setting up internal components and then get on to the external ones. You will need to consult your motherboard manual for finding the appropriate port for connecting various cables at the right places on the motherboard.
  • Connect the large ATX power connector to the power supply port on your motherboard041a.jpg
  • Next get hold of the smaller square power connector which supplies power to the processor and connect it to the appropriate port by taking help from your motherboard manual
  • Connect the cabinet cables for power,reset button in the appropriate port of the motherboard
  • Connect the front USB/audio panel cable in the motherboard
  • Plug the cable of cabinet fans
You are done with installing the internal components of the PC. Close the side doors of the cabinet and get it upright and place it on your computer table. Get the rest of the PC components like monitor, keyboard, mouse, speakers etc. which we will connect now.
  • If mouse/keyboard are PS/2 then connect them to PS/2 ports or else use the USB port
  • Connect the speaker cable in the audio port
  • Plug in the power cable from PSU into the UPS
  • Also plug in the power cable of the monitor
You are now done with setting up your PC. Power on and see your rig boot to glory.
Step 10: Installing the OS and driversWe are done with the hardware part. Now get your favorite OS disks ready and the CD that came with your motherboard.
  • Set the first boot device to CD/DVD drive in BIOS
  • Pop in the OS disk
  • Reboot the PC
  • Install the OS
  • Install drivers from motherboard CD (applicable only to Windows OS)
Voila! You have your PC up and running. Enjoy your journey with your self assembled rig!
Jargon Buster
  • CPU - Central Processing Unit
  • RAM - Random Memory Access
  • DDR -Double Data Rate
  • SDRAM - Synchronous Dynamic Random Access Memory
  • PSU -Power Supply Unit
  • AGP - Accelerated Graphics Port
  • PCI-E - Peripheral Component Interconnect- Express
  • SATA - Serial Advanced Technology Attachment
  • PATA -Parallel Advanced Technology Attachment
  • IDE - Integrated Drive Electronics
  • ATX - Advanced Technology Extended
  • USB - Universal System Bus
  • VGA - Video Graphics Array
  • PS/2 - Personal System/2
  • OS - Operating System
Problem installing graphic card radeon hd5670. After installing the card in the PCI slot the pc cannot boot up properly but if i remove the card it can boot up smmothly without any problem... Help me with...
Disable the original driver,put It in a flash drive or floopy ,back up your registry and install your new driver from a place you can find It ..i.e
floopy works best if the new driver has a un-install choice
Powr supply checks out with tester, but when plugged into a BRANDNEW motherboard. Flashes green, Power switch is in and fans are in. Is it possible for P/S to be bad only when drawing from board?
There are many possibilities here. The motherboard could be installed incorrectly causing a short. The motherboard may not support the processor. A hardware device plugged into the motherboard may be shorted. The power supply may be defective under load ( when plugged into everything). No memory is installed on the motherboard. The power supply is too small for the motherboard that was installed. The first thing to check, is to plug in the motherboard connectors only with memory installed then try to power up. If at this point it will not power up, then you have a problem with the power supply or motherboard. If it powers up at this point, then plug in one device at a time starting with the hard drive and try to power up. If it continues to power up, plug in another device. If this process continues work, then you will find that either you have a shorted device or your power supply will not support the motherboard and all of the installed devices. It is also possible at this point that the motherboard is defective, by using more power than it should causing an overload on the power supply with all devices plugged in.
Im trying to install a sata dvd drive on a gigabyte motherboard 8s648fxp-rz
hello, i understand u want to connect an dvd/drive for laptops with a pc/mainboard...
it is possible to connect the devices, but when buying the adaptor, inquire how the dvd-drive will be powered then, for in an laptop the power is provided via the s-ata plug whereas is pc u have an extra power cord!
u will have to get either an
IDE(PC,big flat data cable, male) to small S-ATA
(laptop)adaptor
or
an USB 2.0 to external S-ATA/ dvd/drive adaptor
(slower than IDE, but safer and less complicated, just plug and play, u need just to install drivers)
good luck, btw internal dvd-drives for PC are pretty cheap :-)
My Bios not run more. My AN35N ultra is dead
find someone who has a computer that you can get on line with.
youll need a floopy drive on both your computer and the one your using, go to the manufactures support website and download the bios file for your motherboard to the floopy. then take the floopy and put it in your computer and start it up. it should download the bios to your system.
if you dont have floopy drives, you can use a usb drive if your systems are set up for usb, but your boot order also have to be setup to recognize the usb.
if this is an older computer you most likely have a floopy drive.
hope this fixes your problem.
would appreciate your leaving feedback for me
thanks.
2answers
Motherboard 755-a2
I go Why can't I install Windows XP on my S-ATA HDD by SiS964? A: You have to copy the driver paired with the motherboard package into a floppy disc before you installing WinXP or Windows 2000 on your system, and follow the notice showed on the screen to insert the floopy disc. The system will grab the needed driver from the disc to finish the installation of S-ATA HDD automatically.
Because SiS964 was announced before than Windows XP and WinXP therefore it can't recognize it. If you want to install a whole new WinXP (or Windows 2000) on S-ATA HDD by SiS964, you need to copy the necessary driver from the directory named floopy image on your driver CD to one floopy disc. When you begin to install OS, follows the instruction to put your disc into floopy drive. After this, you will keep on installing your WinXP smoothly. If you use P-ATA HDD, you don't need to do like this.
t this off the sis.com web site what does it all mean.
Mother board
about the small connectors, there is white text printed into the motherboard showing what goes where.
about the drives, check your cables.
Top Gigabyte Computers & Internet Experts
MegaByteMe
MegaByteMe
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
