Canon EOS 400D / Rebel XTi Digital Camera Logo
Posted on Sep 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I change the display so that it shows images before I take the picture...so I don't want to look through the ''eye'' part, just have it show up on the screen.
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Sep 03, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2197934
Points
38521
To do that, your camera must be capable of "live view". Does yours? Check your manual if you're not sure.
Desact monitor
When the following symptoms, that is, to replace a laptop LCD screen:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
The screen don't show image
press the eye/lcd button just under eye piece.
Picture does not show on LCD screen when opened.. Picture ok in eye viewer..
Sometimes there is a button to change from using display to eyepiece.
look for something like that. I have that when i shoot video or pictures with my camera.
Garmin Nuvi 1490- I have loaded JPEG photo's but none will show up in picture viewer. i have changed the file size to a smaller format, but nothing shows up. i have loaded images on both the unit and...
The pictures must be in the "JPEG" folder of either the GPS's internal memory or external SD card to display. Acceptable formats are: JPEG, BPM, GIF, BNG, TIF, and others.If you are having trouble, resizing and / or reducing the number of colors in the picture may help. If you save or convert the image to GIF, it will automatically be reduced to 256 colors.
Play back screen does not show any image it is just showing a blank white back ground
A component called CCD IMAGER is faulty and needs replacement, Basically the component works as an eye to view the image when it start malfunctioning screen and viewfinder does not show image. The detail of said part is given below:
Part No. Description
8-753-244-71 ICX611NKF-13 (CCD IMAGER)(HC51E/HC52E/HC53E/HC54E)
For convenience area is marked with red circle in the picture below:
Thanks
2helpful
2answers
Friends are reporting a display image in messenger that I am not seeing. How do I delete it when I can't even see it?
To change your display image on yahoo messenger follow these steps:
Login to your messenger,
At the top left corner is an icon which looks like a face directly under the messenger tab of the messenger,
Click on the face icon,
An extension comes out with manage display image,
click on display image and decide if you want to share an image or not as well as change whatever display image shows there.
Hope this is helpful
1helpful
Why LCD monitor can not show image
It might be that it accidently change the display time of the picture or turned it off. There is a setting that you can change to display pictures. Check if that might be the problem.
Cheers
Cannot change image display with yahoo messenger
Image not showing...black horizontal lines instead
Was it fixed by an AUTHORIZED service center.
Sounds like the CCD/sensor has failed, which is the eye of the camera. Go to a reputable place, I know one in Florida, but I don't know where you are.
2answers
Pictures won't show on screen
I have checked to see if I can simulate your problem on my D70.
There are no settings on the Set-up menu to turn off the display.
The display should show for a minimum of 6 seconds after a phot is taken.
You can reduce the screen brightness but that will not turn it completely black.
I presume you have eliminated all other possibilities by changing batteries, card, lens etc..
If so, it would suggest an LCD screen failure which would necessitate a repair by a Nikon agent.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
