Question about Meridian Two-Line Corded Business phone
Cannot dial out on my Meridian 9516 telephone
On my Meridian 9516, I am not able to dial out on.I have a dial tone but the number is not going thru nor am I able to answer an incoming call. The calls are announced, caller ID works. so what's the problem.
Is the Program button on . If it is turn it off. You can also try resetting the phone by unplugging the silver line cord from the phone or the wall jack and then replugging it after about 10 seconds.
see if that works
Posted on Sep 03, 2009
6ya staff
SOURCE:
The keyapd on my meridian telephone sets do not output any tone after a call is complete.
Key pads are for buttons, not dial tone.
When a call is complete it should be silence.
If you want tone then press Intercom or a Line or an Access code.
Dec 17, 2012 | NorStar Meridian Norstar T7208 Corded...
How to delete message
Double tone more often called stuttered dial tone means you have a message in your mailbox. This message system is controlled by your carrier who supplies your phone line so you need to call them and ask for the * code to check messages as well the password they have set it at.
Sep 25, 2012 | NorStar Meridian 9516 Corded Phone
No dial tone, check line cord
Just that!
There is no dial tone at the jack or you have a bad cord.
Aug 09, 2012 | NorStar Meridian 9516 Corded Phone
No dialing tone?
It is a phone designed for use with PABX telephone systems in businesses, it is not suitable for use on a standard phone line.
Mar 10, 2012 | NorStar Meridian M2616 Phone
Is this service free? After a thunderstorm, our two Meredian 9516 phones will not work. The phone lights up and says extension in use but no dial tone, just a busy signal. Does the phone need to be...
Extension in use means there is not enough battery showing on the line. On our Nortel phone, unplugging the line cord gets the same result (actually check tel line because it's no voltage). Take a phone out to the demarc point outside and plug it into the jack there. If you don't have dial tone, report it to the telco. If you do, then you have an inside wiring problem.
Carl
Apr 04, 2011 | NorStar Meridian 9617 USB Telephone with...
How to program speed dial on T7208 telephone?
Programming
memory buttons
External autodial
1. If you are on a call or an open line with dial tone, press Hold
or Rls
2. Press Feature * 1
3. Press a memory button.
4. Dial the external number.
5. Press Hold to store the number.
6. Label your new button.
Internal autodial
or Rls
2. Press Feature * 2
4. Dial the internal number.
5. Label your new button.
Features
or Rls
2. Press Feature * 3
4. Press Feature and the feature code.
Erasing memory buttons
or Rls
3. Press the memory button you want to erase.
4. Press Hold to erase the button.
Feb 13, 2010 | Nortel Meridian M7208 Corded Phone
We had a thunderstorm and a transformer was struck by lightening. I have no dial tone. Do I need another AC Adaptor. The display screen is blank. My other telephone worked ok when I plugged it up....
What all you need can be decided upon after eliminating the faulty items one by one. First the AC adapter. Check with another device if the adapter is functional. Or if you have a multimeter. Next the phone, try another adapter. Where from? Read the specs printed on the adapter. It will tell you the Input and output voltages. Then it also tells you about the frequency. Then the wattage. If all of them match or come close you can use it. Trip to the store is warranted. Thunderstorms and lightenings generally do not leave anything intact. So, I hope your phone is intact. Adapter can be replaced easily.
Aug 05, 2009 | Meridian 9516 Corded phone
Can not view caller ID with call waiting service
The Meridian 9516 is not a visual call waiting (VCW) phone...meaning that you will not see the caller name and number of the second caller when you are on the line..you must purchase a separate call display box (around $10) if you can still find them., but make sure that box is visual call display capable.
Sep 24, 2008 | NorStar Meridian 9516 Corded Phone
Norstar m7310 phone
Rushy: I assume you have a KSU which controls the entire system. The KSU is cabled to each line number provided by your local phone company. Once you have this line established it now makes contact with your phone set via dedicated cabling to each telephone set.. With all this hardware in place you can now program the line keys on each set for either one touch dialing or line access for your dial tone. Program guides can be aquired through GOOGLE by entering " Norstar m7310 program guide".Thank You. Jerry
Feb 08, 2008 | NorStar Meridian M7310 Phone
Meridian Two-Line Corded Business phone Logo
221 people viewed this question
Top Meridian Lands Phones Experts
Marvin
Marvin
Ekse
Cabanaboyz
Cabanaboyz
Are you a Meridian Lands Phone Expert? Answer questions, earn points and help others
