SOURCE: serger blades do not cut.
For now, it works only satisfactorily:
I applied alcohol to further clean both blades,
dried and then oiled them. There seemed to be a slight gap between blades;
the fabric was dragged into the gap instead of being cut.
SOURCE: The foot in my elna 704 broke. Where can I take
go to Elnausa.com and check out dealer locater.
sewman7
SOURCE: the needles on my elna 704 serger keep breaking.
Check to make sure you have the right size needle for sergers. Your blades may not be align properly.
SOURCE: Elna 704 serger sews well but cutter won't cut.
Make sure that the blades are being held firmly together. I have seen the knob used to lower the moving blade come loose and releases much of the pressure intended to hold the blades together. If so, the set screws on knob have come loose.
