MOTOR:
21?2 H.P., Hobart designed, high torque ball bearing,
ventilated within mixer enclosure. Single-phase is
capacitor-start, induction-run type.
Three-phase is
polyphase squirrel cage, induction-run type.
Single Phase 208V 20.0 Amps
240V 17.0 Amps
Three Phase 208-240V 8.6 Amps
You would need to supply an ML number of your machine, Your date plate has that. It would also be necessary to know the voltage spec of your machine. 1 or 3 phase, 208 v? Does it have a bowl guard, or timer? Please relist your needs . State your concerns, I could probably help you from just that. Hobart don't usually give out service data due to liabilities. If you injured yourself testing the machine, and you are not factory trained, you can imagine the ramifications.
