How to adjust the picture size when the camera takes photos.. Whereby using up the entire CARD SPACE? Standartd size is what I want 3x5 or 4x6 approximately..
Every picture comes out 17x11 or thereabouts.
Your suggestions are appreciated..
That size that is being recorded is the default large pixel dimensions giving you the 17x11. You can reduce the pixel dimensions to something smaller like the medium and small settings, but you loose detail. You are better off using a photo editor to crop to the correct size on a computer like Photoshop Elements, Photoshop, Microsoft Picture editor and more.
Just about any photo kiosk at a mall or printing lab will auto crop to the size requested regardless of how big the file is. I always crop to the right size in Photoshop to submit my files online to a lab.
This may not be the solution; however, please obtain a larger capacity memory card.
A 2GB card will give you several hundred photos. Cost is less than $10.
You really should not lower the resolution. you will lose detail that you may want in the future (really). (4GB card will hold over 999 pictures - $15)
If you must lower the resolution, press "Menu" and use the arrows to move the highlight bar to "resolution" ... change it to a lower number like 6MP. keep the "FINE" setting in place (if your model has that setting) or maybe "BEST".
Do not use "RAW" - (very large pix).
Hope this helps!
