Locks & Locksmithing Logo
Alex Humme Posted on Jul 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kaba auditcon model 552 is currently shut the codes I have do not work to get it open for me to reset how do i reset it to open? can I do this locked
Chris Walker
Level 3:
Top Expert:
  • Locks & Lock... Master 1,573 Answers
  • Posted on Aug 01, 2019
Chris Walker
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1244407
Points
21965
3 Related Answers
woobie dog
woobie dog
  • 1273 Answers
  • Posted on Jan 21, 2011
SOURCE: lock fail to open, L1000
Start with a puff of graphite dust, and work the key in and out of the lock, causing the rake on the end of the key to move the pins and springs up and down. Do this several times. Then, place the key in the lock, but not fully. Leave the key out of the lock 2 pin's worth. Tap the back of the key with a screwdriver **** (like a hammer blow, but softer), while applying slight pressure in the direction that you want the lock to operate. This is known a springing the lock, and is quite easily done, if you already have the right key. Don't give up, it may take up to 20 attempts to get the lock to spring. Each time that the lock doesn't move, return to the "locked" position, reset your hey to the "two pins out" position, and tap again. Once the pins clear the shear line, open the lock. Re lubricate the lock after it has been opened, and you are ready to lock it back.
Best regards,
--W/D--
Anonymous
  • Posted on Mar 08, 2011
SOURCE: How to reset codes in Kaba ilco Unican 4000 access control
The factory-default master code for Unican 4000 is 12345678
Anonymous
  • 963 Answers
  • Posted on Aug 24, 2012
SOURCE: kaba lock won't open with code
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Kaba lock won't open with code
Do not no the code to my unican 5 # lock
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Hover your mouse over "PDF" under the "TIPS" column and the two choices of "Changing the Code/Combination" or "How to Reset a Lost or Unknown Combination" will appear--move your mouse over the appropriate one and click to download the info.
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader, if the file will not display for you.
Door lock push button not working, reset lock at top of lock box works for a day and then buttons won't work.
I can't answer your question directly, but i can steer you toward some contact and technical information:
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Had to replace a return spring under the clutch and now the clutch arms won't reset the combo pack if a wrong code is entered.It does work if the right code is entered
I recommend that you contact Kaba Ilco directly with your problem.
We have installed a KABA E-PLEX 2000 with several access codes and too many people have aquired the codes. We wish to wipe out all the codes and start fresh. We were given a master code but are unable to...
Programming instructions for your lock can be found here:
Good luck--and please provide feedback if this helps!
WE HAVE THIS LOCK INSTALLED AND IT HAS THE TYPICAL FACTORY SETTING CODE (2/4 THEN 3). WE DON'T KNOW HOW TO CHANGE IT! HELP
Lock failure where can i get these repaired cheap.
Bought a house with a Unican 7000 series keyless lock on it. I have the current code but want to change it. Can someone tell me how I can change the code?
Yow will find a link to download the manual for your model on this page:
Zero old key code and enter new key code on KABA electronic keypad
http://www.kaba-ilco.com/access_control/literature/literature_grid_eplex.aspx?id=14
Top Locks & Locksmithing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
