Question about Lexmark X6150 All-In-One InkJet Printer
Lexmark x6150 - I have just replaced the black ink cartridge and it won't print. Am I missing something?
    Novelist:
  • 136 Answers
It's possible that your printer has an automated alignment process, that may need to be completed beofre it will accept "jobs" from the PC. Check the printer display for instructions (perhaps a menu for "aligning cartiridges". Also, some have a self-scan process... when you powered it up, did it print a page with a bunch of little lines on it? If so, you re-insert that page into the scanner, and hit "scan" to complete the process. It should then be ready to go!
Hope this helps!
-- RT
Posted on Sep 03, 2009
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Lexmark X6150 says balck cartridge missing
Must use a new cartridge.
Posted on Jun 23, 2009
Lexmark S405 : printer will not print until the black ink cartridge is replaced
Smash printer with axe or sledgehammer. Grin maniacally. After researching on internet,go out & buy new printer that allows you to print till empty & refill again! Obviously not a Lexmark...
Jul 21, 2012 | Lexmark Interpret S405 Wireless All-in-One...
My black ink all of a sudden won't print and I get an error message that says remove tape from cartridge...there is no tape...it is a Lexmark 6150
If the problem continues even after re-seating the black cartridge and cleaning its nozzles, then it could be a faulty cartridge issue. Replace it with a new genuine Lexmark cartridge.
Aug 23, 2011 | Lexmark X6150 All-In-One InkJet Printer
I have an x6150 and it had been working fine. I ran out of ink and replaced the cartridge not too long ago. I printed a few items (not much) and all of a sudden when I hit print, it acts like it is...
Print quality issues could be due to clogged or dirty print cartridge nozzles. Try the steps below to improve print quality on your Lexmark X6150 printer:
  1. Load paper in the All-In-One.
  2. On the printer operator panel, press Copy.
  3. Press Options until Maintenance appears on the display.
  4. Press the right arrow until Clean Cartridges appears on the display.
  5. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  6. Print your document again to verify that your print quality has improved.
You may also try to insert a different known working cartridge to determine if it's not a cartridge issue.
Aug 16, 2011 | Lexmark X6150 All-In-One InkJet Printer
I just got a new black ink for my Lexmark X6150 printer and when I did the alignment test, it turns out a like dark grey instead of black. The printer also said to remove tape from ink but all the tape has...
You should try cleaning your cartridge nozzles. If you're using Windows, go to Start -> Programs -> Lexmark X6100 Series -> Lexmark Solution Center -> Maintenance tab -> Clean to fix horizontal streaks. The printer will then print a test page.
You can also manually clean the cartridge nozzles. Follow the steps in this article : How to Clean the Print Cartridge Nozzles and Contacts Manually.
Thanks.
Feb 10, 2011 | Lexmark X6150 All-In-One InkJet Printer
My documents will not print the colored part. just Black and white
I would first check to see how low the color cartridge is. If it is out of ink, you will need to replace it.
Your Lexmark has two cartridges, one for colors and one for black.
To check the level of the ink cartridges, go to the Lexmark Solution Center. This is the software that was installed to run you Lexmark printer.
Check the cartridge ink level images that appear on each tab. If a cartridge is low, or if you have received an Ink Low message on the computer screen, install a new cartridge. An empty or low cartridge is marked with an exclamation point ( ! ).
To order print cartridges:
1 }}--> }}-->Open the }}--> }}-->Lexmark Solution Center .
2 }}--> }}-->Click the Contact Information tab.
3 }}--> }}-->Click Ordering Ink and Supplies.
For help installing a cartridge, go to How to install the print cartridge.
Dec 30, 2010 | Lexmark X6150 All-In-One InkJet Printer
X6150 keep showing 0502 error when printing
I fixed my friends printer, Lexmark x6150 which had the same error and symptoms. The registration strip might be out of its so called slot but I doubt it.
Get several cotton balls and a bottle of rubbing alcohol. Turn off the printer. Soak a cotton ball, not dripping or saturated with the alcohol. Clean the paper path ( area underneath where the print cartridge carrier travels back and forth over the paper. ) This area becomes coated with ink and gets sticky, Clean the area until all ink is removed, you will use many cotton balls, continue until clean. Check the carrier parked area. You will note 2 rubber boots, 1 for each ink cartridge, make certain they are clean as well. They seal the cartridges so they don't dry out.
Jan 10, 2009 | Lexmark X6150 All-In-One InkJet Printer
Lexmark x6150 won't print after being stored
If you havent tried this already......try to reprint several times......this has worked for me in similar situations......you may just need to give the ink a chance to do its thing
Dec 12, 2007 | Lexmark X6150 All-In-One InkJet Printer
Lexmark X6150 All-In-One InkJet Printer Logo
159 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
