You can download this PDF instructional manual for the Evenflo Discovery
car seat:
https://www.google.co.il/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&cad=rja&ved=0CHUQFjAH&url=https%3A%2F%2Fplweb.evenflo.com%2FShowDocument.aspx%3FManualID%3D583&ei=A8UtUbW5AY_Z4QSCjoDoCA&usg=AFQjCNFj1O1EuRQVLmKwgOLTJsL6yoeOTQ&bvm=bv.42965579,d.bGE You
can also read this article on how to adjust the harness straps on an
Evenflo car carrier:
http://www.ehow.com/how_6391052_adjust-evenflo-car-carrier-straps.html
Evenflo has a GREAT website section on using and installing their carseats. The manufacturer is the final authority on keeping your child safe in their seat: don't accept advice from anyone else! http://www.evenflo.com/sme_carseats.aspx?id=321
You also ought to have your instruction manual for reference: order it for free, at this link: https://plweb.evenflo.com/replacement_parts.aspx
Look in the back of the carseat and you should see where you can adjust the straps and then pull the length trough the front of the carseat. I don't have an evenflo, but sometimes there's a clip you can move forward to make the straps longer.
You're trying to unattach the straps from the wrong end....flip the car seat over and on the very bottom there is a little gold clip that pops out and you can push through the hole.
Okay okay--do not do anything with the big pieces behind the babies back but the gold clips at the **** area..pop those out and shove that piece and the clip and the chest clip through the back of the strap hole--then reput the strap through the slot you wish then the gold pieces back through the bottom and of course pop the gold pieces back--again do not use the upper clips behind the back to do this :0)
If you push down on the top of the handle you should then be able to move it. Also, to remove the straps you have to feed the bottom portion of the straps from underneath the seat up through first and then you should be able to feed through the material to remove the pad.
Just in case you don't still have the number;
1-800-233-5921, Monday - Friday from 8 am to 5 pm.
I've asked them to send me a manual but i doubt if i can get it before the end of the holidays - here's hoping.
https://plweb.evenflo.com/faq_detail.aspx?faqid=4990
Question:
How do I care and clean for my PortAbout 3/PortAbout V infant car seat?
Answer:
To clean pad slide the elastic loops of the seat pad off of the seat shell. Remove the harness system. Cloth pad, canopy, and head support may be machine washed separately cold water, delicate cycle, tumble dry 10-15 minutes, low heat. Wipe straps, buckles, and harness adjusters with warm damp cloth and mild soap. Air dry. NOTE: DO NOT submerge harness assembly in water. To help protect the vehicle upholstery, place a towel beneath and behind the child restraint.
