Wharfedale DVD-M3 DVD Player Logo
Posted on Dec 07, 2007
Error code hi ,i have a wharfedale dvdrhd400f that doesnt seem to now pick up on tuner,,,,i think i got it too hot and has maybe overheated,,,,the code i get on front is e3750 any ideas would be helpful.
  • mikeharbour Jul 08, 2008
    I had this error code E3750 and no freeview, tried the factory default restore and when it comes back on you do get the cahnce to change the clock - but.......... is still has no free view. I am taking it back to the shop.
  • Anonymous Sep 18, 2008
    I have a wharfedale DVD/HDD recorder 2 years old with a simlar E3750 problem. Since getting the error message the tuner no longer receives sound. I've tried turning it off, factory resets etc many times, all to no avail. As it is out of warranty now I have no choice but to write it off as a waste of money.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 23, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1498
Points
I have a Wharfdale DVDRHD400, on inputting the type of screen in the set-up menu I by mistake made the wrong decision. After this I cannot get past the SETUP menu, it appears to see the screen, but this is blank. Has this unit an external reset button, if so where is it !!!
Would running down the internal battery solve this problem, as all information should be lost.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Jan 28, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6288
Points
I've had that when trying to reset the clock with no Freeview input.
Maybe same / similar problem to which someone has posted the following
posted by msladsy on Dec 21, 2007
Report abuse
When the initial set up ran for the DVD recorder it set the correct time and, I assume, the correct date.
However, I had problems with the display and went through various settings until I solved the display problem.
Unfortunately, during the process, which included disconnecting the power, the clock was reset, starting at midnight and 1st January. There appears to be no way to access the clock.
How do I get the recorder to display the correct date/time?
Mark
Comment by msladsy, posted on Dec 21, 2007
This solution may work for other Wharfedale DVD recorders as well as the DVDRHD400F.
Use your Setup button to acces the 'Setup' menu.
Choose the 'Preferences' menu.
Choose 'Factory Defaults' and click on 'OK'.
The recorder will restore the factory defaults and the first screen it takes you too is the 'Initial Setup' screen where it asks you to enter the correct date and time.
Mark
Comment by msladsy, posted on Dec 22, 2007
May work on similar dvd recorders. Would help if Wharfedale included this in their users manual.
Hope this of use
A
Anonymous
I had the same problem - turn off at the wall and on again fixed it.
What are thermostat symptoms
Hi Typical problems arrising from a faulty thermostat are, overheating, water pipes pressured up verry hard, warm water in the expansion tank and or radiator but engine hot, and it might even throw up an error code maybe P0604.
Hope that helps
My dvd player show set up how it works from this problem
I have no remote control of WHARFEDALE / Model - DVDRHD400F /& it shows "setup" error How can i operate it....
Speakers not working
I have a wharfedale 32 HD Ready didital LCD TV and the headphone socket does not seem to work...have used four working headphones that work on Ipods and Hi Fi but they do not work on TV is this a tv fault or do I need a mono small jack on headphone ?
My Wharfedale CD player just seemed to stop working one day,
Your friends are probably right however the correct term is the laser alignment is off or it just conked out. If you aren't afraid, open the case to see if there is any debris in the cd drive. Go to an office supply store and pick up a can of computer duster.
3helpful
I have a wharfedale DVDRHD400F It stopped working suddenly I cant sitch on there is only a small blue flasjing LED on the front what might be the problem and can it be fixed. It happened before and I left...
This is a common fault with these units there is a problem in the power supply ( leaky capacitors ) the manufactures used the wrong type 85c not 105c thus the break down.
Do not attempt to repair this there are very high voltages and can kill ask a qualified person with the correct equipment to carry out this work for you
DVDRHD400F tuner has no sound.
Yep -same problem, but I bought mine for £18 at an auction, thought I'd done so well, but no warantee!!
-Doh. Sound perfect from DVD, so not a scart issue. Tried factory reset / retune, no joy. Freeview silent. Warfdale, you used to be the best in the world; what's gone wrong? :(
1helpful
Wharfedale dvdrhd400f
have the same problem. DVD's play back with sound OK, but the tuner has no sound. any advice?
2answers
Wharfedale dvdrhd400 problems
Change the Scart setting (in the setup menu) from the default setting (RGB) to the other available setting (CVSC?).
I have a problem with my box restting the clock on a random basis, making it impossible to set a timer to record anything - let us know if you get the same problem via this site!
Setting the clock on a Wharfedale DVDRHD400F
Try scanning for channels. It may well download time and date automatically.
3helpful
2answers
Wharfedale DVDRHD400 Set up Issue
Hi I had the same problem. The answer is to use a scart lead on the freeview box and connect it to the input/output scart on the DVD. Then connect a scart lead from the TV out on the DVD to the TV. You then press Video source on the DVD remote until 'scart' is displayed to pick the freeview channels. Hope that helps
Top Wharfedale Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Steve Pack
Steve Pack
Are you a Wharfedale Televison and Video Expert? Answer questions, earn points and help others
